Question about Whirlpool Duet GHW9150P Front Load Washer
Error f11 and error f01 and error f28 displays
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 continues to show on display.
Comunication error between motor control unit and Central control unit. Broken wire in the harness.
F01 power glitch: disconnect power for 2 mins verify correct CCU operation
F11 Motor control unit internal failure MCU board failure or broken wire.
F20 No water detected entering machine, pressure switch hose clogged
F21 Long drain Possible cause: Clogged filter, clogged/failed pump
F22 Door lock error Failed lock. corrosion,or broken wires.
F23 Heater Failure Bad heater
F24 Water temp sensor error Failed sensor or heater
F25 Motor Tach error Bad MCU (motor control unit) or broken wire
F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
F27 Overflow condition Clogged drain, pump, kinked hose.
F28 Com error between MCU and CCU (central control unit) Broken wire
F29 Door unlock error bad switch,broken wire,corrosion
F30 Dispenser system error Bad or jammed motor, broken wire
F31 MCU failure due to motor overheating.
F33 Pump drive system error, broken wire, corrosion
rL (prewash)Clothes detect. Remove clothes and retry.
5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
For diagnostics and further info refer to this handy dandy:
DUET SERVICE MANUAL My tip:
http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
Mar 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Our Kenmore Elite 46752 Washing machine is displaying codes "F11"
I'm sorry to hear about your trouble and it may not be good news, I'm afraid. The F11 code is a generic code generated to indicate a communication error between the motor control board and the central control board occurred. The F28 code indicates a problem at the motor control board. The wiring connections have been known to jiggle loose and become corroded, which can trigger these codes, but if removing, cleaning, and reseating the electrical connections doesn't fix the problem you are looking at possibly replacing the control boards. Plural, because there is no real way to tell which control board is causing the problem. I would lean toward the motor control board since the F28 code was generated, but that would still be speculation. Again, sorry for your trouble and I hope this helps. Best wishes.
Aug 30, 2009 | Washing Machines
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
