Question about Hannspree HANNSpad Tablet User Manual
Donde esta el apn - Hannspree HANNSpad Tablet User Manual
I want to update my apn data setting from T-Mobile to straight talk
the best thing to do is contact t mobile the apple tech can help you with. that
Jan 01, 2015 | Apple iPad (16 GB) WiFi Tablet PC
3g dongle support
Hi
Seems like it needs to be configured, though not all tablets support dongles i.e Karbonn-Samsung Galaxy and lenovoA1000 & A30
First, (1) put 3G sim into dongle and connect dongle to tablet. You may have to wait several minuets for tablet to find internet, if it does not, continue as below.
2. Now go to 'settings' and select the 'More' option .
3. Select 'Mobile Networks' > 'Access Point' Name (APN) 4. Then select New APN option.
5. All you have to do now is make the following changes in the bracketed entities [ Name, APN and Dial Number]:-
-> Set the network name. Eg:- For Tata photon just write Tata or TP or anything, as you like it.
-> Set the APN,> search the net for your service provider's APN. Then write it precisely.
-> All the dongles come with dial number. Check your dongle purchase paper or the manual or just search it Google. And then fill the same here as the Dial Number, save and you are done. eg. For Tata Docomo it is #999 and Reliance it is #777.
NOTE:
After plugging the dongle, a default APN gets created in the APN setting's page.Try to feed the settings by creating a new APN.
Karbonn, Samsung Galaxy and Lenovo A1000 & A3000 tablet does not support dongle.
By far and large the above steps will work with all the dongles and Tablets. You could also go to 'You Tube' and seach for Video info which may be quite helpful. Regards Silverfox160
Ssssss
Aa
You can aaa
aa
a
Aug 27, 2014 | Irulu 7 Inch Android 4.1 Jelly Bean...
How do I edit and save apn settings?
Android 4.0 manked up the apn controls, unfortunately there isnt a simple 'covers everything' solution. Search the market for 'APN settings' and hope fr the best. Each carrier and phone has a totally different compatibilty list.
Aug 08, 2014 | inDigi 7-inch Phablet Smart Phone Tablet...
What is the apn settings straight talk
It is best if you contact Straight Talk for APN settings.
Mark
Mo
Aug 01, 2014 | Motorola Mobility Atrix 4g Mb860 Quad-band...
Sony xperia troubleshooting
I don't knwo if your problem is troubleshooting or 404error
1-solution for troubleshooting:
No plug-ins are found
  • For some phone types and in some countries, there might not be any plug-ins for the LiveView application.
Your LiveView micro display is automatically turned off
  • The battery level is too low. Charge your LiveView micro display.
  • Pairing failed. Enter pairing mode again.
Unexpected behaviour
To reset your LiveView micro display:
  1. Make sure that your LiveView micro display is turned off.
  2. Press and hold the Power key for approximately 8 seconds until your LiveView micro display is turned off again.
The phone media player cannot be controlled from LiveView
  • LiveView supports the standard Android media player. If your phone manufacturer has removed the standard Android media player, LiveView will not be able to control it.
2-solution for 404error :
A/
clearing the PROXY in the APN settings. If you're on ICS, do the following. Open the Settings > More... > Mobile Networks > Access Point Names > [Your APN Name] > Proxy - clear this field.
OR
B/System Settings > "More..." in Wireless and Networks > Mobile Networks > Access Point Names (APNs) >press the menu button, inside the menu press "Reset to default" > now another option will appear called "Internet 3G" (modem) , besides the "Portal 3G". Choose the new option "Internet 3G" and you are done!
Good Luck
Jul 04, 2014 | Tablets & eReaders
Activate sim card
You should check you network service for the Apn they use. You may have to insert the apn on the tablet to get the data
Jun 02, 2013 | Lenovo Tablets & eReaders
Refacciones para tablet sharper image 9
donde puedo conseguir el display touch para una tablet 9 pulgadas the sharper image modelo mid900sc
Jan 12, 2013 | Tablets & eReaders
When i power my hp tx2000 it display all lights and the cap light is flashing but there is no display at the screen even it does not boot, what can i do to repair it.
mi computadora tiene un año 6 meses es una tx2627cl ; derepente comenzo a pitar y cada vez que la prendo pita y el lector de huellas digitales no reconoce y esta lenta que hago ayudenme porfa es urgente
Jan 14, 2011 | HP Tablets & eReaders
Como puedo acer que lea el cd/dvd externo para cargar sistema ope
Prueba con un CD externo. Conectalo por USB.
Muchas veces los CD/DVD roms se malogran.
Suerte.
No olvides de Rate esta respuesta si te fue util.
Dec 04, 2009 | Toshiba Portege 3500 Tablet PC
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Hannspree HANNSpad Tablet User Manual Logo
18 people viewed this question
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
yobo007
yobo007
ka4iup
ka4iup
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
