Question about Vehicle Parts & Accessories
Avital remote starter starts then shuts off and starts up
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
logosc75
  • 625 Answers
SOURCE: can an avital 4113 remote starter be installed in
Yes, just program the wait to start to 15 seconds.
Posted on Sep 16, 2010
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
Posted on Jan 26, 2011
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
Avital 4113 remote starter shuts off after a few seconds
check and scan vehicle if you have a pending code remote starts wont work correctly or wont start at all or need to check and test unit for possible fault or wire problem
Dec 15, 2016 | Avital Vehicle Parts & Accessories
My remote starter shuts off as soon as it start
The ignition wire has not been wired in2 the system then - try checking all the wires r connected properly!!!! Good luck!!!
Nov 22, 2013 | 4103LX Remote Start System with Two...
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
What does the brown shutdown wire on avital 2001 ford taurus connect to
The brown shutdown wire on Directed Electronics remote starters connect the switched positive side of the foot brake. You step on the brake, the remote starter shuts down.
Aug 14, 2012 | Avital Vehicle Parts & Accessories
Howto disable 24 hr timer in avital 4400
Remote start the vehicle; turn ignition on with the key. The parking lights will flash 4 times indicating that the timer mode has been exited.
Please note how the timer was activated by pressing the lock and unlock buttons.
When in the timer mode, the remote starter can time out or, you can shut down the remote starter with the remote and the timer mode will remain active. But, if the remote start sequence is terminated by any of the shutdowns ( ignition, brake, hood or neutral safety switch) while the remote starter is running, the timer mode will be terminated.
Feb 03, 2011 | AviStart 4400 2-Way Security / Remote...
We had the Avital 4003 keyless engine starter remote installed on our 4Runner in July when we purchased it. We shipped the car overseas and now that it has arrived the renmote will only start the radio...
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Sep 26, 2010 | 4003L Avital 4003 Remote Start Module...
Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Dec 23, 2008 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
