Question about Duke E101-G Gas Single Oven
Duke e101-g motor wiring - Duke E101-G Gas Single Oven
3 Suggested Answers
  • 106 Answers
SOURCE: hi,
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Posted on Jul 29, 2010
  • 223 Answers
SOURCE: I have a duke e101-g
Generally, when you wish to change the fuel for a gas appliance all you have to do is change the orifice. Most appliance dealers will be happy to order a LP orifice for your oven for you.
lp
Posted on Dec 30, 2010
Hi My duke 6/13 oven is smoking and is not supossed to do that Any advice on this matter ?
check to see if any food has dropped on the elements, if it is food then monitor it until the food is burnt off , if it is not food i would turn it off at your fuse box and call an engineer or like minded family member to take a look at it, hope all goes well.
Feb 07, 2017 | Duke Ovens
Why would a duke E101-G will sometimes work fine and sometimes dont I replaced the thermostat but it is doing the same thing
When you have a high end oven like this you will find that the manufacture stands behind it. try to find a 1800 number and talk to parts. they will probably want you to talk to an approve alliance repair person but if you ask the right questions and listen between the lines you might find out what you need to know to fix it.
Dec 10, 2014 | Duke Ovens
Why would a duke's manufacturing co oven model E102-g stop heating ?
An erratic thermostat, heating element, or both.
Jul 28, 2014 | Duke Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
I have a duke e101-g oven and I want to convert it to propane what should I get?
lp
Dec 30, 2010 | Duke E101-G Gas Single Oven
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
I have a defective flame sensor on a duke oven, I need to know the best way to remove it to replace with a new one. It does not appeear there is enough room inside to access it.
it does require removal of entire burner assembly. which is not all that hard to do but a bit time consuming. fittings for 2 burners and pilot must be disconnected and 3 screws on front of burner assembly. unit will then pull right out allowing access to flame sensor bulb. hope this helps!
Apr 22, 2010 | Duke E101-G Gas Single Oven
Problem with duke 613 commercial oven
http://www.4emweb.com/search.asp
try this web site. I found a list of wiring diagrams here..If you have a problem getting there, let me know and I will give steps as to how.
Good luck.
May 23, 2009 | Duke 613-E1V Electric Single Oven
Duke E101-G Gas Single Oven Logo
18 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Duke Oven Expert? Answer questions, earn points and help others
