Question about ACDelco 1989 AC DELCO 15-71968 GMC S-15 Pickup Blower Motor Resistor AC De
I need see how the vacuum lines go - ACDelco 1989 AC DELCO 15-71968 GMC S-15 Pickup Blower Motor Resistor AC De
Vacuum line diagram for a 2000 nissan Quest 3.3l engine
William, Vacuum line hoses diagram, This is what I found, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Repair Guides Vacuum Diagrams Vacuum Diagrams AutoZone com
2000 nissan Quest 3 3l engine Vacuum line diagram Google Search
Aug 17, 2016 | Nissan Cars & Trucks
Vacuum lines melted need video were vacuum lines go
you really need to get you a Chilton book for your explorer it will have the diagram in it you need for vacuum and also it will help for other issues you may have but for sure it has all the vacuum diagrams you need they cost $20.00 and well worth it if your local advance or auto zone don't have you can print it from Chilton.com or Haynes.com
Apr 11, 2014 | 1999 Ford Explorer
Need a vacuum hose routing diagram for a 99 VW Beetle 2.0
VACUUM LINE DIAGRAMS
There are few direct links showing exact vacuum line diagrams. I suggest you to refer the direct links.
Click the link below: -----
How to locate the vacuum leak?
http://howtobyme.blogspot.in/2012/01/how-to-locate-vacuum-leak.html
Vacuum Hose Routing Diagram For 1995 Chevrolet Corvette Throttle Body?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-hose-routing-diagram-for-1995.html
VACUUM DIAGRAMS For Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/vacuum-diagrams-for-audi-a4.html
VACUUM DIAGRAMS For VW Passat?
http://vwrepairhelp.blogspot.com/2011/11/vacuum-diagrams-for-vw-passt.html
Vacuum line diagram For 1996 Chevrolet Lumina?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-line-diagram-for-1996-chevrolet.html
Vacuum diagram for Isuzu?
http://technoanswers.blogspot.com/2012/01/vacuum-diagram-for-isuzu.html
Ford 4 wheel drive vacuum solenoid working system?
http://technoanswers.blogspot.in/2012/02/ford-4-wheel-drive-vacuum-solenoid.html
These will help.
Thanks.
Dec 06, 2012 | 1998 Volkswagen Beetle
87 buick century won't shift out of first
The first thing is to check the transmission fluid level, then check the vacuum modulator located out on the side of the transmission, and be certain that the vacuum line is connected to the vacuum modulator, and that the vacuum line also has no leaks and it is connected to an intake manifold vacuum source. If you remove the vacuum line from the vacuum modulator and if there is any transmission fluid is in the vacuum line then the vacuum modulator is faulty and it will need to be replaced.
Sep 21, 2010 | 1987 Buick Century
I need a vacuum line diagram
Use a industrial vacume tester, check each port coming off of the manifold, run your lines.
Apr 21, 2010 | 1977 Chevrolet Silverado 2500
My f150 4x4 wont engage and i have already change the actuator at both wheels and the thing on the fire wall the vac lines go to and still no 4x4
You may need to work upwards from the wheels past the thing on the firewall. If the part on the firewall has vacuum lines coming out of it, then it must have a vacuum line going into it to provide the vacuum.
You need to trace the vacuum line and see if it has vacuum. You can unplug the line to test it by listening for the hiss as the engine runs or get a vacuum gauge or vacuum pump.
It may be something simple like a broken knob on the dash control that is slipping around the stem the knob attaches to.
Feb 27, 2010 | 2005 Ford F-150
2000 beetle bulb for heater control
yes you can. You will need a pair of pliers a thin rag one that is not to bulky. and a piece of vacuum line. like the vacuum line on your car. small. well first you need the replacement bulb get at dealership it is small. that will be the size of vacuum line you need. with the pliers carefully pull off your fan speed knob you will see the bulb back in the hole. take the vacuum line push onto the bulb twist line and pull it should pull the bulb out. then put new bulb lightly into vacuum line look at the slots where the bulb goes you will need to line up the bulb should be straight up and down. push bulb in you will feel slight click then reverse the way you turned the vacuum line to pull out just the line. and you should be good make sure the bulb lights up before you put the knob back on. good luck
Sep 12, 2009 | 1999 Volkswagen New Jetta
Loose vacuum line, need to know where it goes
vacuum drops at a higher rpm..ac system does have vacuum line goes to a small plastic ball it stores vacuum ..either that ball is broken or the one way check valve in line is bad
May 20, 2009 | 1997 Chevrolet S-10 Pickup
1998 olds 88 heater off switch is on a vacuum line
Have you checked the vacuum line with a gauge? If so, how many pascal units does the vacuum line read? Vacuum gauges are around $5. Furthermore, I believe the design is sealed vacuum only system. The solenoid could be bad, but to my knowledge it is not an electrical component. A split in one of the vacuum lines could be cause of your problem. You would have to trace the all the vacuum lines back to the source to find the problem. You would need that gauge to detect a leak in the system. Could also replace all the vacuum lines on principle since the vehicle is going on two decades.
Mar 31, 2017 | Oldsmobile Regency Cars & Trucks
Corvette, 1985, lost vacuum to A/C control switch: need vacuum diagram and/or any help I can get...fan is OK, just blows out of all vents at one time.
look for a vacuum pod or tank under the hood. this is most likely where the interior vacuum controls get the vacuum. Does the pod have a line that connects to the intake manifold, or the brake booster? It should., if not find missing vacuum line and repair. Follow the other vacuum line from the pod to the interior, (it is important to find the line going to the interior, as there may be more than one at the pod) is it connected to the controls? it should be. Here is a simplified verbal schematic... vacuum from engine to pod, vacuum from pod to vacuum controlled devices. GM often color codes the interior vacuum lines and that makes them easier to follow under the dash.
Sep 21, 2008 | Chevrolet Corvette Cars & Trucks
ACDelco 1989 AC DELCO 15-71968 GMC S-15 Pickup Blower Motor Resistor AC De Logo
77 people viewed this question
Top ACDelco Electronics - Others Experts
Are you an ACDelco Electronics - Other Expert? Answer questions, earn points and help others
