Ovens Logo
A
Anonymous Posted on Feb 13, 2014
Oven failure fo3
Model no. AKZ 511/IX 858551115001
1 Related Answer
Paul Davies
  • 157 Answers
  • Posted on Jun 30, 2009
SOURCE: Hi on the display of my oven reads
element
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Akz 451 timer, clock, light and fan all working - oven not warming up - power RCD tripped before fault noticed
I would recommend that you replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Our Whirlpool OBI C10 Oven has stopped and is displaying FO3 on the panel. I switched the supply off and on to try and reset, but to no effect. What is the cause?
Hi
Thanks for using FixYa. Error F03 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
I had an ignis build in, single, fan oven, model AKL907/IX installed in January, worked fine now, switches off when the oven is on, beeps and then can be restarted if pressing the ok button, however the...
Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
Aug 15, 2010 • Ovens
Whirlpool AKZ 446 Electric fan starts but oven does not heat up ?? Is the element easy to replace/fit? Thanks
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
AKZ 451 will not heat up
element,make sure clock is set though
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 • Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
