Question about IBM (47P9291) Motherboard
IBM 4800-124, CPU Unit - IBM (47P9291) Motherboard
http://www-01.ibm.com/support/docview.wss?uid=pos1R7000011
Feb 13, 2014 | IBM (47P9291) Motherboard
Laptop shuts down a few seconds after starting
My IBM is about the same as yours and did the same thing. It turned out to be a CPU Cooling Fan. When you turn the laptop on, try to look in the air outlet port and see if the fan is turning. Another possibility is lint and dirt around the fan. The unit has a temperature sensor that will shut the machine down on a "Hot CPU" signal.
Dec 03, 2010 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad t23 shutting off after 10 minutes or so
Your CPU is overheating and the solution is a laptop cooling pad which will save you the cost of another motherboard.
Apr 13, 2009 | IBM ThinkPad T23 2647 Notebook
IBM T20 start up problem - CPU fail
update or reflash youre bios(eeprom)
you can download the program off the net.
search for bios firmware....download the software ...write it to cd..reboot with cd in drive , software will flash bios ...remove disk ..reboot.
Jan 07, 2009 | IBM ThinkPad T21 Notebook
IBM 25P2590 P4 micro motherbord
i found nothing but items referencing updates and patches to existing servers and software to accomodate the situation you describe.. if you're still nervous try looking around on ibm.com/support or lenovo.com/support
Dec 29, 2008 | IBM (25P3294) Motherboard
IBM T41 WILL NOT STARTS UP SOMETIMESTHEN WHEN IT DOES IT FREEZES
problems will be with:-
1:- installed memory ( not enough or damaged memory module ) RAM
2:- The Processor ( CPU ) Is Overheating.
3:- Hard-Drive. The unit may have bad or defective sectors.
4:- Computer Virus Or Similar.
Solution:- remove 1 memory module from the computer ( located on the underside computer ) boot the computer. see if this helps. try changing memory between the 2 allocated slots.
Check the CPU Fan, is not clocked with dust/debris. ( Can be accessed by removing 2 screws on the underside or the laptop ) Marked with >> or similar. remove the fan, 3 small screws and brush with a soft dry paint brush or similar, remove any dust from fan and check for blockages.
run a scandisk or hard-drive checking program, to test hard-disk unit et,c.
following these steps, should solve your problems.
Mike @ Compurepair. " Thankyou For Using Fixya "
Nov 22, 2008 | IBM ThinkPad T40 2373 Notebook
My IBM Monitor doesnt turn on but the CPU is on.
You may have changed setting by mistake so while powering cpu first time press f8 f8 frequently and you will go to safe mode and see the picture
Oct 29, 2008 | IBM ThinkVision L170 17" LCD Monitor
CPU Upgrade
I think its an intel P3 socket 370.
Oct 01, 2007 | IBM ThinkPad T22 2647 Notebook
Computers & Internet Logo
14 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
