Question about Coleman Four-Way Quad and Micro Quad Lantern
I installed the batteries in my lantern...first time, and the cover will not close.
It is a screw on lid, and just keeps going around and around, even with heavy pressure on it.
Energizer WeatherReady lantern came with batteries; worked once. Can't unscrew the top to change batteries. Possible battery corrosion? Is there a workaround fix?
Mix water and baking soda together until baking soda is dissolved.
Take a small baking pan or a bowel with a flat bottom and place the lantern in a vertical position, bottom down and slowly pour in the baking soda solution so the solution is 1/4" above the battery lid so the solution can soak into the threads of the lid. Let sit overnight. Next morning, slowly lift the lantern out of the solution without tipping it keeping it vertical, and slowly unscrew the lid over the sink. Keep in mind there will be solution inside the lantern when you first open it, so be careful not to tip it until you dry out the inside.
Aug 31, 2016 | Energizer Camping, Backpacking & Hiking
How do you install 6V battery into Dorcy luminator
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
Oct 28, 2012 | Dorcy International p6V Floating Luminator...
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
The windows and sun roof doesnt work i think i have a blown fuse
The fuse and relay box on the E30 and E36 models is located in the engine compartment. The E36 models also has relay boxes located under the left side of the dashboard.
Circuit Breakers
Resetting & Replacement
Circuit breakers are located inside the fuse panel. They are automatically reset when the problem corrects itself, is repaired, or the circuit cools down to allow operation again.
One of the less known about fuses that can cause all this to go out is the fuseable link. It is in a black plastic box near the battery. It is an appx 60A thin metal strip fuse. Check the website link to the right for more info.
Also, I suggest check your Fuse Diagram in the BMW 525i Owners Manual here.
Power Sunroof
Emergency Closure Operation
The sunroof is equipped with an emergency closure feature should the sunroof motor fail or the vehicle has lost electrical power. To close the sunroof under these conditions:
  1. Remove the front headliner trim panel.
  2. Using the 6mm hex key that is included with the tool kit, insert the key into the hex socket and turn the socket to close the sunroof.
Fig. Remove the trim panel to access the sunroof motor
Fig. Insert the 6mm hex tool from the tool kit and turn the hex socket to close the sunroof
Removal & Installation
E30 Models
Fig. Sunroof components-E30 3 Series shown, E36 similar
Fig. Sunroof lid retainer clip location-E30 3 Series shown, E36 similar
  1. Open the sunroof lid 2-4 inches (5-10cm).
  2. Unclip the roof liner frame and push back into the opening.
  3. Close the sunroof lid and loosen the screws on each end of the gates.
  4. Pull in the retainers, remove the center screws and lift off the lid.
  5. Remove the cover over the motor and gearbox. Close the sunroof lid, if not already closed.
  6. Disconnect the wiring harness and remove the 3 mounting screws. Remove the motor and gearbox.
  7. Push the cables back evenly on both sides. Remove the rail covers and pull the cables out of the guides.
  8. Place the cable in the center position of the gate and press off.
To install:
  1. Install the cables to the gate. The cable are marked with the proper side of installation. Do not lubricate fabric covered cables.
  2. Pull the cables through guides and align the cables. Insert a hex key through the gate and cable at the 0 position.
  3. Install the motor and gearbox. The motor and gearbox must be synchronized with the hole in the drivegear aligned between the centers of the 2 gears. Torque the bolts to 2.0 ft. lbs. (2.8 Nm).
  4. Install the sunroof lid. Use new screws and torque to 2.5 ft. lbs. (3.5 Nm).
  5. Adjust the sunroof lid. Pull the roof liner frame into position and clip into place.
E36 Models
  1. Close the sunroof fully. With a quick actuation of the sunroof opening button, open the sunroof so the back edge of the lid depresses 0.08-0.12 inches (2-3mm).
  2. Slowly push the roof liner panel back into the roof. Do not force or use a quick motion or damage could occur.
  3. Remove the mounting screws and pull the lid off at the rear side. Do not operate the sunroof with the panel removed.
To install:
  1. Install the lid and check that the hooks and levers align. Install the screws with threadlocker or use new micro-encapsulated screws. Torque to 2.5 ft. lbs. (3.5 Nm).
  2. Adjust the sunroof lid. Lower the rear of the lid by operating the motor. Pull the liner forward and clip into place.
Good luck.
Mar 15, 2010 | BMW 525 Cars & Trucks
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Jun 30, 2009 | Camping, Backpacking & Hiking
Fuji s5100 batter door cover prongs are broken off.
I have the simple and cheap fix to a frustrating problem!
Just take a tripod base and screw it into the bottom of the
camera. The square tripod base is large enough to hold the battery
cover on the camera closed without any interference.
So there you go! No tape, rubber bands or other crazy contraptions!
Cheap, Quick and simple.
Steve in Tampa, FL
Apr 21, 2009 | Fuji FinePix S5100 Digital Camera
Security
go to tech support and get something called a recovery disk it will cost you some money though and there could be other ways to
Jun 24, 2008 | Compaq Armada E500 Notebook
Battery lid or cover
I have a s5500 with the battery lid clips broken.. fuji says ,, nope no warranty on that part ,, what a joke,,$120 dollars labour plus parts and freight for repair... anyway ,, went to jaycar (electrical supplies etc) and found a small metal clip/ fastener that I used on an existing exterior screw below where the strap is located. i then placed another screw in the lid that allows the remainding hole in the fastener to slip over, works like a charm. took me around 3 minutes to do and does not affect the grip on the camera and still alllows it to be easily opened and closed. I am most pleased i now have my camera back.
Feb 10, 2008 | Fuji FinePix S5100 Digital Camera
Coleman Four-Way Quad and Micro Quad Lantern Logo
155 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Ted Maxwell
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
