Question about Polaroid TDX-01930B 19 in. LCD HDTV
How watch dvd - Polaroid TDX-01930B 19 in. LCD HDTV
Use dvd player without remote control
just able to watch the first show of my series dvd. is it somehow possible to watch the other shows of the dvd AmanStino Mouse Pad with Gel Wrist Pad grey9 0 7 8 AmanStino
Nov 30, 2016 | Teac Televison & Video
We can't watch DVDs as it says DVD blocked for
your player probaly has something wrong with it and ur tv is telling you not to use, so buy a new dvd playeer
Dec 27, 2012 | Televison & Video
Great picture but really loud static when watching dvd
Hook the DVD to another TV set, this will prove if the player is the issue or original TV
Mar 19, 2012 | Yahoo Diamond Vision DVDC803-04 DVD Player
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
How do I watch a movie?
You should be able to put the DVD in the tray and should automatically recognize it and go into the movie.
What type of media are you trying to watch. PS2's cannot play blu-ray movies.
Mar 09, 2011 | Sony PlayStation 2 (PS2) Console
It's not working. The profanity still comes through when watching a dvd. I tried setting the tv on caption cc2. I think I did that. It did not make a difference.
U can't not stop profanity,if u watch NC17,PG13 or Rated R DVD movies.Captioning CC1,2,3 dosen't effect the DVD movie.It only have captioning on the tv that in tv brocasting shows,not in the DVD movie.If u want no profanity in movies watch PG movies.
Mar 17, 2010 | RCA DRC247N DVD Player
I want to program my remote to dvd
Hi there. You can set up a Watch DVD Activity by doing the following:
1. Click "Add Activity" 2, Select "No - manually..." 3. Seect "Watch DVD or Laserdisc" 4. Select "Watch a DVD ( DVD player)" 5. Click NEXT, and go through the setup. 6. Update the remote.
Hope that helps :)
Feb 25, 2010 | Logitech Harmony One Advanced Universal...
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Samsung dvd vr357 Can not watch copied dvd on other dvd players
I know with the Go-Video, the DVD disc has to be 'finalized' before it's compatible with other DVD players/computers.
Check your 'set-up' menus while that disc is inserted into your Samsung DVD machine and see about pushing the 'up' arrow, if you have one, to see the contents of the DVD disc...then see if you can toggle to the right to see options for that disc, for instance, the title of it. You might see the 'finalize' option there.
Feb 27, 2009 | GoVideo VR3845 DVD Recorder/VCR
Dvd driver
are you trying to watch dvd's from a disk ??? unless you have a dvd player installed it wont work , example, power dvd installed ? here is a free dvd player you can download http://www.avsmedia.com/DVDPlayer/index.aspx after you install this you should be able to watch dvd's with this program, and media plarer 11
hope this helps
Nov 20, 2007 | Compaq Evo D510 Minitower (Open Box)...
Polaroid TDX-01930B 19 in. LCD HDTV Logo
19 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
