Question about LeapFrog Scout My Puppy Pal
Music button broken - LeapFrog Scout My Puppy Pal
I have an LG G Vista. The volume for the Music, Video, Games & other media keeps turning itself to zero. Is there any way to lock it?
Not that I can think of... Sounds like the volume down button is either stuck or broken. Push down on the volume down button, does it "click". If not, it might be stuck, try getting a razor blade and pull up on the volume button GENTLY. If you pull it up and still no click when pushing down, than the button is broken in my opinion.
Sep 21, 2016 | LG G Vista
My phone is on but it wont turn on, it is playing music but wen i press the power button it wont turn on how do i fix this.
Are you sure the button are okay? It could be that the button is the one thats broken. If not, its probably problem with the OS, you should restore the OS then
Nov 02, 2014 | Apple Iphone 4 - 16gb - White gevey...
Recently my n73 phone has fallen on the ground and after this the volume button for up has been broken. this means i can only lower the volume or zoom out or any other thing that i can do with these...
No need to ask for software as well as tricks.I thought that there is no way to increase without changing the broken broken button .My comment is to contact mobile repairing shop.But it is up to you.Good luck.
Jul 21, 2011 | Nokia N73 Cellular Phone
Eject button no work. also will not burn photos or music, do I need to purchase a new one,? the part is disconected and removed from computer
I have a couple questions for you. 1. Does it burn anything? Data files like text files or exe files? If not could be broken. 2. Does it read cd/dvd's ok? If so it could be a driver issue that need to be reinstalled to fix the burning part. If it does not read cd/dvd's then it is probably broken and needs to be replaced.
As for the broken eject button that is more than likely a physical problem and the burner maybe worth replacing just for that fact.
Good Luck.
Apr 29, 2011 | Computers & Internet
F4 button pressed in
Most of the Roland buttons on this type equipment use a small switch that is actuated by a plastic button that is HINGED from a plastic panel behind the faceplate or a part of it. These plastic hinges get broken when too much force is applied to the button... it is USUALLY fatal and requires replacement of the whole button faceplate... and they are expensive... contact Roland parts to inquire.
Mar 01, 2011 | Roland Mv8800 Production Studio
LG DLGX8388 Steam Dryer. Controls inactive.
Make sure drive belt is not broken
Jan 29, 2018 | LG Dryers
Broken Triton push button
I am not familiar with your exact model, but if the plastic "hinge" for the button has broken, it is possible to "fix" it. This is not a DIY repair though. Can you tell me where you are located so I can perhaps suggest a repair location?
Thanks,
Dan
Nov 04, 2009 | Music
Problems
try putting it in recovery mode, detach it from anything like a charger or pc make sure that it is off, press and hold the play button while powering on, when you see the logo release the play button, for this problem you must se;ect the reload os firmware and then follow instructions
Mar 28, 2008 | Creative Labs ZEN V Plus MP3 Player
Sandisk m230 mp3 player
make sure the play button is not broken
Dec 26, 2007 | SanDisk Sansa m230 MP3 Player
Rio Forge 256mb volume button broken
I had the same problem. I took it apart and found a plastic piece broken off. I think I'm hosed!
Nov 14, 2006 | Rio Forge Sport Digital Media Player
LeapFrog Scout My Puppy Pal Logo
37 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
