Question about Panasonic Heating & Cooling
CS-G125KE error code F99
Display is showing error code F99 with flashing timer lamp
4 Suggested Answers
  • 124 Answers
SOURCE: New airconditioner (installed 5 days
do nothing on a brand new unit but let the installer or service tech fix it for free, if you go messing with it you may camoflouge the real problem and when the repair tech arrives he wont be able to observe the actual cause or fault and it will do it again after hes gone and you'll be back to square one. please don't touch a thing till the tech arrives and gets the chance to see it broken and use his tools to determine the problem. good luck.
Posted on Dec 05, 2008
  • 821 Answers
SOURCE: Pasonic Model CS-E9DKEW CU-E9DKE Runs for
Hello,this is simply caused by the compressor,you will have to get it serviced,but if the problem persist,then i would advice you replace it.
you can as well check the following,because below is the translator of the H16 error code,
H16 Outdoor Current Transformer open circuit
• Outdoor PCB
• IPM (Power transistor) module
take care.
Posted on Dec 05, 2010
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Posted on Dec 11, 2010
Model CS-E12NKR. What does error code F99 indicate?
Outdoor Direct Current (DC) peak detection
7 times occurrence continuously
Check: • Outdoor PCB
• Compressor
Chances are that the outdoor board has gone. You need a megger to check the compressor first before buying a new board.
Nov 13, 2015 | Panasonic Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
May 11, 2013 | Sharp Heating & Cooling
It shuts off and blinks 11
AHX18MEV
4 - 12
1. Indoor unit
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Minolta EP2030 shuts off immedietly when I power it on
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Jan 22, 2009 | Minolta EP1083 CS/PRO Copier
Heating & Cooling Logo
69 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
