Question about Uniden DECT 6.0 Cordless Phone
When you put the phone on the base is it normal for the red light to blink on and off?
Model number d1680
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a Uniden cordless phone EZI996, The lights
Hi.
Try the following procedure to reset and re-sync the phone system:
  • Disconnect all units from power.
  • Remove batteries from all handset.
  • Check all phone connections to base.
  • Check the phone connector underneath the base (RJ11 squared plug).
  • Put back battries on handsets.
  • Place handsets on base.
  • Connect base back to power with handset sitting on base.
If that does not fix the problem , then there is an internal fault. In that case call Uniden to arrange repair or replacement.
Uniden support number for your area is prited inside the user documentation.
Regards.
Posted on Dec 05, 2009
  • 11 Answers
SOURCE: when you dial the number the phone rings once and
you'll need to contact the manufacturer for a repair, or take it back where you bought it and exchange it. it's broken.
Posted on Jan 22, 2011
The red ID button keeps blinking even when I have no messages. How do I stop it
You might try to reset the Voice Mail Waiting Indicator ( V M W I ).
To reset the Voice Mail Warning Indicator
on the D1680 and similar handsets:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Blinking light stays on after msgs have been deleted
That might be the Voice Mail Waiting Indicator which
is NOT part of the answering machine system.
On the D1680, D1481, and similar handsets,
it is reset (turned off) by:
1. press [menu]
6. press [END]
Apr 12, 2016 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT6.0 Model D1680 Problem: Need to change recorded message ,cant get past Security Code_ a 2 digit pin .Forgot what is was..
The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
Apr 01, 2016 | Uniden D1680 Cordless Phone
The answering system red blinking light is working on all three handsets all the time, even when there is nothing left on the answering system.
That might be the Voice Mail Warning Indicator.
On the D1680 and similar handsets, it is reset by:
1. press [menu]
6. press [END]
Jan 15, 2016 | Uniden Cordless Phone
Read and deleted all messages. MessAGE LIGHT STILL BLINKS
That sounds like the Voice Mail Waiting Indicator.
1. press [menu]
6. press [END]
Dec 13, 2015 | Uniden DECT 6.0 Cordless Telephone...
Why is red light flashing when there are no messages on the machine?
1. press [menu]
6. press [END]
Oct 22, 2015 | Uniden Cordless Phone
How do I turn off voicemail light?
To reset the Voice Mail Warning Indicator ---
(( On the D1680 and similar handsets ))
1. press [menu]
6. press [END]
Sep 01, 2015 | Uniden DECT 6.0 Cordless Phone ID
Message light blinking but no messages.
That might be the Voice Mail Waiting Indicator which works
with the telephone service provider's 'VoiceMail' feature.
On the D1680 and similar handsets, it can be reset by:
1. press [menu]
6. press [END]
copy of the User's Manual if needed.
Apr 21, 2015 | Uniden Cordless Phone
Uniden base flashing 88 8
I just got off of the phone with Uniden for the same issue with my D1680-4. The alternating "8" - "88" code is an indication that the base is dead. They will be sending me a new base (and 2 handsets). During the call I learned that if you do not have a receipt, Uniden warrants their phones for up to 15 months. The advertised 12 months, plus 3 months for the product to get from manufacturing, through distribution channel and finally sale to the consumer.
Feb 17, 2012 | Uniden D1680 Cordless Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
Uniden DECT 6.0 Cordless Phone Logo
14 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
