Question about LG LFC25770ST (250 cu ft) Bottom Freezer French Door Refrigerator
How to turn off ice maker in french door with ice in a drawer
How do you turn off ice maker in french drawer ref. that has the ice maker in bottom freezer
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
MNTECH
  • 1543 Answers
SOURCE: error code IF or 1F not making ice model #795,77562... Sears/LG
You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
Posted on Jan 11, 2009
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
  • 400 Answers
SOURCE: Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Posted on Mar 05, 2009
Maytag317
  • 1136 Answers
SOURCE: the bottom of my lg french door bottom freezer
Hi, The defrost drain is plugged. UNPLUG the refrigerator. Remove the rear inside panel in the freezer section and locates the drain hole below the evaporator coils. You will have to melt the ice in the drain hole and flush it out with hot water.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 05, 2009
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
The ice from the ice maker tastes and smells funny.
Look for your Ice maker replcement cartridge at the bottom of your french doors...
Sep 17, 2011 | LG LFC25760ST 25 Cu. Ft. Panorama French...
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Ice maker quit working
go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
Jan 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Aug 30, 2008 | Samsung 25.5 Cu. Ft. Side-by-Side...
Ice maker spills ice
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
Jun 29, 2008 | GE PFS22SBSSS Stainless Steel French Door...
LG LFC25770ST (250 cu ft) Bottom Freezer French Door Refrigerator Logo
15 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
