Question about Acer Aspire One D255 Laptop
Adisk read error occurred - Acer Aspire One D255 Laptop
    Problem Solver:
  • 20 Answers
Run check disk asap
Posted on May 01, 2014
2 Suggested Answers
  • 788 Answers
SOURCE: THERE IS AN ERROR WHEN I START MY COMPUTER, IT
Try to enter your BIOS and on the last page, reset your configuration to default.
F-10 to save and try it.
PS have all external devices disconnected before making these changes.
It looks like you nic card or netwk boot rom is trying to load.
And also, if you do not have a A drive or floppy drive installed, disable it in the BIOS as well.
Remember to save when you exit.
Hope this info has helped you.
Posted on Sep 30, 2009
A DISK READ ERROR OCCURRED
Try Windows7 instead of XP, since XP doesn't support SATA drivers to read your HDD
Jul 08, 2014 | Biostar GF7025-M2 GeForce 7025 Socket AM2...
That usually means that your HDD (hard disk drive) is dead and its no longer readable. By start up pres F2 normaly thats the button normaly that will lead you to the BIOS go on overview and see if your HDD is still detected by BIOS. You can also try to see how bed things are by inserting a rescue disk on your CD/DVD drive press F12 when you do that and try to diagnose the problem. You can also try to reinstall your OS(operation system) sometimes that also helps but not in many cases. I Hope that help you a bit.
Feb 13, 2014 | Acer Aspire One D255 Laptop
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
When you connect ur transcend 4gb pen drive if this message appears please insert adisk into drive H:
This usually happens when one of three things occur.
1) the drive is not formatted or has a file system not compatible with the os
2) there is software on the drive that cuases a fake cdrom drive to install and it did not install correctly
3) user is clicking the wrong drive letter
confirm with my computer the drive is formatted and to what type
confirm in device manager that the drive is installed
Jun 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
"A disk read error occurred. Please click ctr +
You have as it states, a disc read error which means you have errors on the hard drive.
As soon as you get into your system run CHKDSK/F, that will attempt to restore the damaged files.
Make backups and look for a replacement hard drive.
Hope that helps.
Feb 16, 2011 | Acer Aspire One PC Notebook
Sharp m205 error u2 Problem, what does mean?
press 0 U2 if 04 occurs EEPROM read/write error (serial communicationerror) if 11 occurs Counter check sum error (EEPROM) if 12 occurs Adjustment value check sum error (EEPROM) if 40 occurs CRUM chip communication error
Jan 11, 2011 | Sharp AR-M205 Copier
Http://www.fixya.com/support/t3058946-error_when_start_computer
""THERE IS AN ERROR WHEN I START MY COMPUTER, IT TELLS ME PXE-E63 ERROR WHILE INITIALIZING THE NIC, PXE-MOF EXTITING INTEL PXE ROM, AND ADISK READ ERROR OCCURRED, HOW CAN I FIX IT""
Disregard the PXE-E63 Errors. The only one to pay attention to is the "Disk read error occured". Some Acer models always give these errors but as far as I can tell the PXE errors are nothing to worry about and thus have never given me any issues in my career.
Reseat the Hard drive when the machine is switched off and power is unplugged and battery is disconnected.
If you can test the hard drive for bad sectors OR if it picks up in another machine by installing it into a external hard drive casing. This case can either be mini-IDE or SATA.
Also you could get a bootable hard drive tester and test the hard drive on your machine to work-around the above.
As a final suggestion, replace hard drive and send in original hard drive for data recovery if needed.
May 25, 2010 | Acer Aspire 3000 Notebook
Sep 30, 2009 | Acer Aspire 3000 Notebook
Fujitsu siemens amilo laptop
Do you have any cd's in the cd drive or any floppys in? it could also be a usb flash drive or external hard drive. If its none of those check the bios settings and see if your hard drive is in the boot order. If its still doing it after that I would say it could be a corrupted hard drive or corrupted os on the hard drive. If all else fails try to do a system recover using the recovery cd's. if that fails its a bad hard drive.
Oct 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Error code 10-fc06-002 in toshiba a200 after running recovery disks
This is a toshiba error when running recovery discs on your machine. There are two reasons that this could occur, one would be corrupted Recovery Discs and the other is bad hardware (Hard Disk Drive).
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Jun 30, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Acer Aspire One D255 Laptop Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
