Question about Crosley Refrigerators
How do you fix the defrost on crosley shelvodor ct15a2
Coil frosts up.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: frost build on coils - defrost not working
The defrost heater and defrost thermostat are behind the freezer panel.
Must have a model number to locate the defrost timer.
It is elsewhere in the fridge.
Posted on Mar 08, 2009
rockitman187
  • 2559 Answers
SOURCE: icey coils,replaced bunrt defrost heater coils still ice up
Replace defrost timer and defrost thermostat.
Posted on May 13, 2009
  • 15 Answers
SOURCE: Coils keep frosting over
The defroster thermostat is what usually causes a ref/freezer to act this way. It can be changed by anyone handy with tools. You refrigerator schematic should show you where it is located.
Posted on Mar 21, 2010
SOURCE: freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Posted on Jul 26, 2010
Fridge wont cool at all.
Condenser coils do not frost ....If ice (more than just frost) is present in the freezer you have a defrost problem
check the following ....
- air circulating fan in freezer
-defrost circuit .... defrost heater, defrost thermostat, and the defrost timer If you have a control logic board the defrost control is part of the logic board
Sep 06, 2015 | Frost Refrigerators
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
I had water in bottom of kenmore fridge. This is now fixed but soon after I had frost building up on back wall of freezer.
you now have a defrost issue,remove rear panel inside freezer if the evaporator is covered with a heavy ice and frost build-up then either the defrost heater under the evaporator coil is open or the defrost thermostat on top of the coil is bad you need to check both for continuity or the defrost timer if equipped or the A.D.C. adaptive defrost control is bad and not supplying power to the defrost circuit
May 02, 2012 | Kenmore Top Freezer Refrigerator
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley model CRTE171AW1. Water drips from above
the most commom problem is that the drain hole is covered with frozen water or the drain tube is plugged.
Mar 09, 2010 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Refrgerator is not cooling
Hi there
I have some stuff for you to read hope this helps you.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Refrigerators
Refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley Frost free Runs continuously
Try not to panic firstly, if you open the door and it starts to run then it was not running before hand right? or did I miss something?
Temp guage or thermostat I think this is one and the same leave it at a midway position for a while and lets see if it reaches temp in the fridge or not.
Jun 24, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Jan 30, 2009 | Crosley CRS40 Manual Defrost Compact...
Freezer
Not if it says manual defrost in the name.
Nov 18, 2008 | Crosley CRS40 Manual Defrost Compact...
Refrigerators Logo
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
