Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXi model dishwasher has fill word flashes and stops
The dishwasher warms up then stops at the with the fill word lite up
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
SOURCE: E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
Posted on May 20, 2009
traboH
  • 27 Answers
SOURCE: I have purchased a business - with a Hobart LXi -
Contact your local chemical supplier such as EcoLab or AutoChlor to purchase the proper chemicals. Use ONLY commercal dish washing chemicals. Residential detergents like Cascade do not dissolve fast enough and WILL, in time, cause you trouble if used in the LXi.
There should be three colored plastic tubes at the rear of your machine. Red is to be put in a container of liquid detergent, Blue is for rinse aid, and white/clear is for sanitizer. Your chemical salesman should be able to show you how it's done at no charge.
You may also want to register here http://www.hobartservice.com/Manuals/ then download the manuals for the LXi dish machine.
All the best.
Posted on Nov 28, 2009
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
  • 110 Answers
SOURCE: Hobart LXI Dishwasher a P3 code is flashing, seems
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Posted on Mar 16, 2010
What is a E3 code on the lxi hobart dishwasher
I just searched and find no information on Hobart machines
Feb 26, 2015 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Feb 17, 2014 | Hobart Dishwashers
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
Mar 15, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
Mar 11, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Oct 14, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
Nov 22, 2007 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
