Question about Garden
Bobcat 337 hydrolics pressure bogs motor down after it gets warm
When cold or warm no problems after I work it hard it starts loosing engine rpm only when I use travel or boom function.feels like hydrolics pressure is backing up.
bunnydawg
  • 5158 Answers
SOURCE: 95 jeep grand cherokee, hard starting, backfires, when cold
get a couple bottles of gas line antifreeze .. if you don't already use it and add it to the gas.
Robert
P.S. in minus 40 i don't even get out of bed... minus 23 here last nite... isn't winter grand
Posted on Jan 21, 2009
  • 131 Answers
SOURCE: '99 chevy Silverado Z71,5.3 engine.....will not rev when hot.....
try replacing your EGR Valve, or your Oxygen Sensor
Posted on Feb 10, 2009
  • 18 Answers
SOURCE: low oil pressure at idle
how low does the oil pressure drop?? is it below 40?
Posted on Mar 05, 2009
slohry
  • 87 Answers
SOURCE: hard starting and when warms up rpm's drop
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Posted on Apr 10, 2009
  • 31 Answers
SOURCE: hydrolic problem on bobcat
it may be broken
Posted on Jul 14, 2010
1997 nissan bogs down at 200 rpm check engine light is on but dont know the code The truck will sit and idle all day but once put in gear and driven will bog down at 2000 rpm in all gears Was told it was...
Check the fuel pump output. Some will work but not have enough output for the instances you describe. Find a place that can test the fuel pump pressure.
Mar 24, 2014 | 1997 Nissan Pickup
Motor bogs down
could be from cold transmission oil in the transmission.. check that the manifold heat control valve is working..
Mar 04, 2014 | Chevrolet Impala Cars & Trucks
1996 honda will not start under 60 degrees
tune it up. (fresh spark parts work best in cold and for sure damp wheather.
fresh gas?
leaking injectors?
isc stuck closed, and rpm low, hot?
the ecu, anticipates the next cold start,
it knows how much to open the iSC valve, to get a good start cold
and if colder to day, it opens more. (math)
if it (ISC) is gummed up,fas all do, it cant start right
so next time, try %10 throttle, starting, emulating a good ISC.
see?
Jan 07, 2014 | 1996 Honda Accord
1988 sx corolla bogs once warm
BOY,that sounds like the EGR is too far open!Un plug it and see.
Maybe getting the wrong signal from the '88 computer.
Also my be a fuel delivery malfunction.
Fuel pump,filter,fuel pressure regulator.
I need to ask more questions,here.
Mar 07, 2013 | Toyota Corolla Cars & Trucks
95 gmc sierra won't hold steady rpm
Sounds like wiring problems with the engine harness.
The oil pressure not working could cause the hard starting problem.
The idle problem could be a faulty idle air control valve or a vac leak.
I would start with the check engine light and find out what the codes are.
Oct 04, 2012 | 1995 GMC Sierra
Good day: I don't accept that cold starting an engine at 2000 RPM is OK. Those immediate revs on a cold engine are wearing out parts that need oil lube and warm-engine clearances. Is there a simple way of...
I have heard that Fords theory behind that is to supply maximum oil pressure to moving parts sooner. All the Ford products do this and the motors last well into the hundreds of thousand of miles. I wouldn't be to worried about it since there is no issue with it to my knowledge and there is no way to limit the cold start RPM's.
Cold start warm ups are a thing of the past. Better lubricants, engines, fuel injection and other computer controls have made start ups easier on the engine. 30 seconds is barely enough time to warm up anything and after a few seconds oil has already reached all of its intended lubricating points. That first few seconds is the hardest on the engine. Regardless of how any RPM's it is turning.
Oct 20, 2010 | 2000 Ford Taurus
1991 firebird will not idle cold and bogs down while driving
This sounds like a fuel issue to me. If I am not mistaken, this engine has two injectors running on a separate fuses. Remove the air cleaner assembly, and make sure both are firing while engine is running. If so, then check the fuel pressure. If you have a fuel pressure gauge, connect it to the fuel rail, and start it up. Remove the vacuum line from the fuel pressure regulator to see where it is set. You should have at least 36lbs of fuel pressure. If the pressure is too low, check the fuel filter. It may be clogged, or you might have a weak fuel pump.
Also you changed the throttle position sensor, you will need to make sure it is set properly.
hope this helps,
Chris
Mar 24, 2009 | 1991 Pontiac Firebird
1993 chevy pickup hard starting and tach oscilates 200 rpm up and down
sounds more likley you have an air leak this will cause bad starting as it is sucking air in instead of fuel when its cold and wnen it warms up idling will be eratic and misfire check all hoses gaskets relating to the inlet manifold or if its done that kind of mileage crankcase pressure could be the problem but i suspect an air leak yates210456
Aug 22, 2008 | 1991 Chevrolet K1500
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
