Question about Fellowes Powershred 99Ci Cross-Cut Shredder, 17 Sheet Capacity
The cross cuts are not working
The motor is working but not cutting
  • fellow Expert
  • 71 Answers
It sounds as if the gears that turn the cutters is either broken or is turning freely on the shaft w/o engaging the cutters. If this is the case you will have to replace the gear(s). The cost of the gears may entice you to buy a new or refurbished shredder. Below is the manual for your machine, it may be of some help-just maybe.
Fellowes Shredder Manuals
Posted on Dec 19, 2014
Hi,my stihl ts 410 saw cuts out after about 10 minutes work,it restarts soon after then cuts out after about 10 minutes again? any ideas,thanks dave
Sounds like an overheating problem.
Are you working in a well-ventilated area or in direct sunlight?
Check, if you can, the temperature of the motor case.
You might have to take a break more often.
This hot summer has stressed a lot of motors and electronics.
When it shuts off you know it is trying to save itself from burnout.
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
1995 Subaru Legacy TS-R,electric drivers seat stopped working in half down position,all fuses are intact ? I have unbolted & lifted the seat, their are 3 connectors under it,the wires from the blue...
the wires can get cut by the seat movement, these could be the wiring for heated seat that was an extra on some models. the motors can become stuck or even strip a cog. if its stopped working but fuse is fine i would think the bushes in the motor have gone you maybe able to change thes i think this part is still available if not it could be a new motor need, but befor this check the switch for the seat these are a common fault over time, you will need a meter to test the switch check its working and has power. you may need some help to do the next part. to check there is power to the motor while its out use a meter and check the volts at the motor plug and have some one press the switch in both directions. if there is power then the motor is at fault.
Jun 29, 2017 | 1997 Subaru Legacy
The motor continues to run on out freezer. We have adjusted the thermostat until it cuts off but it will cut back on in a short time. We also cleaned out from under the freezer but nothing we try seems to...
Which motor are you talking about, as there is a compressor, a condenser fan motor (located with the compressor), and evaporator fan motor?
It cut's back on shortly as the sensed temperature "cut-in" is reached, and the unit tries to cool things down below that set temperature again.
Dec 14, 2009 | Televison & Video
Motor will not cut on
check the motor resistance, check the connection to the motor. Thermistor may be cut the connection.
Jun 14, 2009 | DeLonghi DE500 Dehumidifier
Motor power question
Horsepower is the maximum power produced by the motor. Saws with high horsepower ratings are good for pattern cutting and cutting down thick stock. Higher horsepower also allows the saw to cut through thick stock without bogging down or burning the wood.
Aug 27, 2008 | Ridgid 14" Band Saw with Stand
Why does my dyson dc04 work for about 5 mins then cut out
I spent 4 years working on Dyson v/ceaners in the Uk
So, heres what to;
Check your filters - and for blokages in the hose and brush comparments,you have one in at top of the bucket called pre motor filter and one on top of the motor where the bucket sits called post motor filter. If these are worn and mucky wash them or replace.
Switch on your Dyson with no filters in and leave running to see if it cuts out. (in side on the motor their a liitle device called a TOC thermal over load cut out device. when the motor runs too warm - the TOC with cut power to the motor and will work again when cooled down.
Good luck.
Mar 18, 2008 | Vacuums
Maytag Model# LAT 8616AAE. The timer seems to work(runs/moves), but certain cycles are missed/bypassed.
sounds like the motor could be cutting out on overload possibly
motor has built in overload
check this first
if cutting out possible faulty bearings in motor
replace motor
Mar 07, 2008 | Washing Machines
Fellowes Powershred 99Ci Cross-Cut Shredder, 17 Sheet Capacity Logo
116 people viewed this question
Top fellow Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a fellow Office Equipment and Supply Expert? Answer questions, earn points and help others
