Question about DeLonghi Coffee Makers & Espresso Machines
Water from water reserve leaking through the seal instead of continuing to capsule etc
Type: EN 266.BAE When pressing either the short or long buttons, the water will just start to slowly come out of the base at the water reserve. Could this just be a blockage at the seal?
3 Suggested Answers
  • 92 Answers
SOURCE: When I insert a new
The Steam valve needs to be replace or rebuild.
I just ordered parts for a machine like this that I'm fixing for a customer.
Posted on Jan 15, 2011
SOURCE: when i turn machine on and put the capsule in i
Turn the machine off with the Power button, and pump the pod receptacle latch on top 3-5 times. Turn machine back on. Ta-Da!
Posted on Nov 07, 2011
Condensation (water) keeps leaking into the building. Have had installer out three times to correct the problem, but it continues to happen. Drain line appears to be clear. No ice or dirt. Seem like...
as i don't know what type your home is, but most water problems relate the to the roof lining seal its the membrane from the roof to the wall chanels water away, it should be fitted all round. another thing can bet the the gutter is in the wrong position, wrong angel or in the seal and when it rains the water will go under the seal instead of down the seal. seal on the sides is fixed both side. but were the gutter are its open sided this is to let air flow around the loft or roof space. hope this helps you find the problem
Feb 04, 2018 | Fujitsu Electronics - Others
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Jul 08, 2011 | Lavazza 2210
When i turn machine on and put the capsule in i press the start button and the water leak out the bottom instead of the spout
Jun 01, 2011 | Nespresso Essenza C100 Espresso...
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
My machine leaks water into the capsul box and doesn't punch holes or not enough in the capsule when pushing it in. Coffee is very weak because not enough coffee is reached in the capsule and water is...
Mar 01, 2011 | Nespresso Citiz D110
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
I have a Kenmore front loader and water keeps on leaking into the tub even though the machine is off.
This is likely due to a foreign object caught in the solenoid valve mechanism - which is usually located at - or very near - the point that the supply water hose attaches. It could also be a faulty seal inside the solenoid valve as well. Either way, changing the solenoid valve will usually solve the problem. Many solenoid valves assemblies control both hot and cold water supply lines, but if yours has separate solenoids - you should determine if it is hot or cold water that is leaking past the seal - and get the appropriate replacement part. Once changed out, the leak should stop.
The washer's water supply should be shut off before the supply hoses whenever not in use. This is especially important if using the cheap rubber hoses instead of the metal mesh type. The hose will eventually fail, and when it does, the water will continue to flow onto the floor until it is shut off by a person.
I hope this helps!
Sep 14, 2010 | Washing Machines
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
LG washing machine WF-F 6861 CN Problem
ne yabba ardhamayye la rayye bae
Nov 08, 2007 | LG Washing Machines
Coffee Makers & Espresso Machines Logo
20 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
