Question about AEG L74650 220volt 50hz 7 Kg Capacity Washer-16224
74650 E40 Hi I am trying to stat the machine and as I select the cycle and select the time it all looks fine, but as I press start, on the display E40 appears and then the drain symbol comes up and it tells me the cycle is finished. i check the door and is properly closed. can any one help please? thank you
  • 1462 Answers
SOURCE: AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Posted on Mar 26, 2007
SOURCE: AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Posted on Mar 25, 2008
  • 38 Answers
SOURCE: machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Posted on Jun 01, 2008
VOTIT
  • 2071 Answers
SOURCE: Washing machine door lock problem
Just try to check the door latch device. Be sure that the latch is not bound or sticking in any way .This problem with a lot of machines and it almost always was the door lock latch assembly. It has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle. The door will actually be shut all the way and the lock may be on. You must replaced this switch so it works normal again..
Just click for the spare parts site link;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
SOURCE: My AEG Lavamat W 1000 runs properly but won't spin
a little late to solve your problem...if it ever happens again, change the 16 micro farrad capacitor in the upper rear right corner of the machine. This capacitor controls the starting torque in any motor mode
Posted on Jan 23, 2011
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
My electrolux washer dryer ewx14540w keeps flashing e40 and won't do anything, please help
Hi dear.Related to your problem,E40 means:
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
Feb 13, 2011 | Electrolux EW1209i Front Load Washer /...
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Feb 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
AEG L74650 220volt 50hz 7 Kg Capacity Washer-16224 Logo
18 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
