Question about Canon imagePROGRAF iPF5100 17" Large-Format Inkjet Printer
My Canon IPF 5100 will not recognize a new print head. What do I do next?
The Printer sat for about a year. when we tried to start it up, it said to replace the left print head. Once it initializes the message light blinks and you can't access any of the menu buttons. even in service mode after following the user guide procedure to replace the head, it just keeps saying replace the print head. There's got to be something that resets the controller to tell the unit a new head has been installed. I can't find that yet.
  • 77 Answers
SOURCE: faulty print head
I beleive instructions are included with the new printhead From Canon's site: You may purchase a print head* for this printer through an Authorized Service Facility ( Find a Service Location) , or by calling 1-800-828-4040 between 8:00 a.m. and 12:00 a.m. midnight, EST, Monday through Sunday. When calling, speak the phrase "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (i9100) or part number (QY6-0039-000) ready for the sales person. * Please be aware that the part is not returnable. That should do it Ed
Posted on May 26, 2007
  • 52 Answers
SOURCE: No ink
hi i am a certified Canon repair tech for this fax. the problem that you are having is very common and has to do with two things. the cartridge and the purge/cleaning unit. what you can try is this open the printer and center the carridge unit and remove the cartridge. unplug the machine while it is still centered. on the right hand side you will see the purge unit. in the center of the purge unit is what looks like a retanglar pad. mix a water soap solution and apply to pad just soaking it. let it sit for a few minutes. take the ink cartridge and wipe the bottom of the cartridge with a damp soapy cloth. also if you look at the cartridge there is a little breating hole you can hold a cloth on the bottom and gently blow in that hole it will purge ink through the bottom of the cartridge. install the cartridge in the machine close the front door and replug in the power cord. you might still have to run a few cleaning cycles. hope this helps.
Posted on Jan 05, 2008
SOURCE: canon faxphone B640
The ink cartridge holder was kind of wiggly, so I put a wedge in the side to push the contacts together more. It worked.
Posted on Mar 12, 2008
  • 64 Answers
SOURCE: Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
Posted on Nov 08, 2008
SOURCE: Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Posted on Jan 26, 2009
Cleaning kit print head canon Image prograf 710
I have always cleaned prinheads leaving them on a saucer with warm water for some time. Preferably, deionized water if it is a problematic printhead. I expect the cleaning kit is something of the sort. But Canon ipf 710 seems to have a fixed use time, having the printer rejecting the printhead after exacly one year use even if it is in perfect conditions. Try to make print test in service mode before you use up all your ink in useless cleanings.
Jul 01, 2014 | Canon imagePROGRAF IPF710 Printer
Canon ipf 6300
Circuit board problem, call Tech support
Mar 12, 2013 | Canon imagePROGRAF iPF6300 Large Format...
My Canon IPF 5100 printer black ink is really fuzzy, I have to prit dark grey as I can't read the black. I have cleaned the heads and done nozzle checks, what else could it be?
If prints are coming out fuzzy this is likely to be an alignment issue. I would recommend doing some alignment tests from your printer/printer software.
Feb 05, 2013 | Office Equipment & Supplies
My print head on my canon ipf 605 wont clean??
I have printer Canon ipf 605 , on display is displayed print head error, I have put new print head, and the problem is the same, I tryed several print heads , most of them new , and it dont want to start....again and again printhead error is displayed...
Dec 11, 2010 | Canon imagePROGRAF IPF605 Printer
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to
Jul 26, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Open Questions:
See all Canon imagePROGRAF iPF5100 17" Large-Format Inkjet Questions
Canon imagePROGRAF iPF5100 17" Large-Format Inkjet Printer Logo
old marine
old marine
