Question about Canon Office Equipment & Supplies
I have new ink cartridges in my printer property installed. Everything is plugged in. When I try to print something from the printer or my computer, the printer spits out blank sheets of paper.
I have a Kodak ESP 5250 All-in-one-printer. While everything appears to be correctly installed and the ink cartridges are relatively new, my printer shoots out blank sheets.
    Scholar:
    New Friend:
  • 49 Answers
There are a couple of nasty little issues regarding printers all alike. usually when replacing ink cartrages there is a chance you upset the print heads when installing. there are 2 ways to try to solve the problem:
1 is usually on the printer theres a feature to print an alignment page or a button to align the print heads, both easy and hard to find depending on the printer, it can take several attempts to work. use it with one deep clean of the print heads for better results.
2 is to manually try to find printer services from the computer side. some printers have it some do not. i cannot guarentee there will be one. using windows 7 go to devices and printers and inside printer properties of your default printer you can find it there if it is there.
Posted on Feb 14, 2014
SOURCE: PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Posted on Sep 01, 2007
PKwilDchilD
  • 44 Answers
SOURCE: kodak printer
check to make sure your ink is in the right place and any cables are in place.
Posted on Jun 03, 2008
SOURCE: Kodak ESP-3 Will not print calibration page. It goes thru the motions, spits out blank paper. This is supposed to happen prior to connecting to computer or installing software. Tried two printheads
I have severe and often different problems with my Kodak ESP-3 printer. Sometime it`s banding of the colors, then I`ll align the printhead and I`ll have a color problem or no color at all. I just talked to Kodak Customer Service by phone, 11 a.m. PST. After a few automated questions I had a live operator in less than 3 minutes. The service tech went thru some diagnostic steps with me and the printer and after about the 5th step determined I had a faulty printer head. If the green on/off light keeps blinking when it shouldn`t be, that is a sure sigh of faulty printer head, it means the printer is not recognizing the head. Kodak seems to be very aware of this problem and are sending me a new printer head UPS, free of charge. After reading some previous reviews I`m suprised how good the customer service was. Maybe I just called at the right time and got lucky.
Posted on Jan 29, 2009
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
  • 108 Answers
SOURCE: No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Posted on Jul 30, 2009
We cannot get out printer to print. easyshare
we replaced printhead and it wants us to calibrate and replace ink color ink cartridge, and before we put the printhead in , it had 1/2 full color in cartridge
Jan 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
HP 3200 Photsmart Printer will not print properly.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Jul 19, 2009 | HP PhotoSmart 1215 InkJet Printer
Black ink not printing or very light or split. Have installed new ink cartridges. Getting some color and headings or seals. But mostly Blank!
HI
Usually when you install new cartridges,the printer print an alignment sheet.
in case if the printer isn't printing the colors okay,
you can try cleaning the cartridges by going to the printer drivers,
goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option for aligning the cartridges,
you can also goto the printing preferences and it allows you to adjust the color
there is an option to clean ink cartridges
Jul 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Prints everything in black and white...
When you try to print something, go to the Properties of the printer, before the final OK to print to see if you can make a selection of the cartridge.
Aug 22, 2008 | HP DeskJet 5550 InkJet Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
I am trying to use a Z705 color jetprinter, but cannot get it to print from the pc. I can print from notepad (not using the print file from the tool bar but from the notepad file. I have tried everything....
May be you are not installed well the software driver of the printer. First check the test page of the printer.
For test page see the option of the printer icon.right click icon goto the properties and click test page. Then it will not print well after that put the driver cd into the cd drive and install the software.try it and if the prob comes again please inform to fixya.com
May 12, 2008 | Computers & Internet
59 people viewed this question
old marine
old marine
