Question about KitchenAid KHM3 Classic Hand Mixer
I need two beaters for the hand held mixer
I have one beater but can't find the other one, so I need to order a set.
SOURCE: KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Posted on Oct 14, 2007
  • 118 Answers
SOURCE: Can't remove beater from mixer...
I would suspect that it has become stuck on the shaft. It depends on what is sticking to what you should use. If it is some sort of food, then soaking it for a while (20-30 mins) with fantastic would loosen it. If its seems to be dry welded, then I'd use something more like liquid wrench (automotive section). Just remember that the locking mechanism requires that you push the beater up, then turn, then pull. so look at the exposed portoin of the beater and see if you can tell what part of the j-channel the pin is located will tell you which way it needs to be moved. I would be not afraid to tap it will a soft mallet (wood or plastic) but not with anything too hard (steel).
Posted on Nov 30, 2008
SOURCE: Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Posted on Dec 07, 2008
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
hslincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
How do I eject the beaters?
Well give me a little more what brand you have. Is it a stand mixer or a hand held mixer? If it is a stand mixer most of them you have to push the beater up and turn to remove it. Most hand mixers have a eject button either on top or in the front.
Sep 30, 2017 | Food Mixers
Find Beaters for Bravetti Mixer
seems to have been already answered on Fixya
Call 1-800-798-7395. I just ordered some for my mixer. Cost $7.95 + $4.95 for 2. Be sure to have your model number when you call.
need beaters for Bravetti 300W hand mixer
Dec 11, 2015 | Bravetti Food Mixers
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
Replacement Beaters for GE Hand Mixer
Hi, replacement beaters can be found at amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Ned
Dec 02, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Bravetti hand mixer beaters
amazon for sure... take a look here: Enjoy Life Sweetest Moments with Sunbeam. I hope I have helped. cheers
Jan 13, 2008 | Food Mixers
Euro-pro hand/stand mixer
I just ordered new beaters for my Euro-Pro EP546 hand mixer. Their website is
euro-pro.com and their telephone # is 800-798-7398. I clicked on Customer Service on their website and asked for assistance, but no one responded. Using the toll free number got me to a live person who took my order over the phone. The replacement beaters are $7.95 plus $4.95 S&H plus tax. Try it.
Sep 13, 2007 | Euro-Pro 300 Watts EP546E Hand Mixer
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
KitchenAid KHM3 Classic Hand Mixer Logo
23 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
