Question about Saws
Evolv brad nailer stopped working when pull the trigger hear air but no action
4 Suggested Answers
  • 1388 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
  • 885 Answers
SOURCE: evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Posted on Apr 09, 2012
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air blowes out the trigger when squezzed
the seal inside is ether out of place or cracked gun are cheap buy a new one
Jan 22, 2014 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
Evolv 2 brad nailer no power
Apr 08, 2012 | Craftsman Air Tools & Compressors
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
I have a poter cable brad nailer and after running
Sounds like a trigger seal. I assume this is an oil-less brad nailer as that is the standard. You should be able to find the seals at any local hardware store including Home Depot or Lowes. If you can't find the portercable O-rings just grab the random assortment from Bostitch which is usually readily available. Refer to your parts manual for the correct size/gauge
Apr 15, 2010 | Porter Cable Cable Brad Nailer and...
My Brad sudddenly stopped working. Makes a Psft
If you've not already tried applying air motor oil to the gun than you should do this first. If this does not solve your problem than it's very possible that your main diaphram is worn or poruse. Thank you, Dana
Mar 31, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Porter cable brad nailer only fires brad on second trigger pull
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Saws Logo
22 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
