Sirius edge Powering down
How i can hard reset on my garmin edge 705
Hard reset : To perform this one holds down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Feb 01, 2017 | Garmin GPS
How i can hard reset on garmin edge 705?
Hard reset : To perform this one hold down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Can my sirius sportster 2 won't receive channel 210
Yep, new radio. The old Sirius radios won't go above 184 (most won't even get above 145) and the old XM radios won't go past 256, so to get the "Xtra" channels you want a new XM radio like the Onyx PLUS, or The XM Edge - both will give you not only all the regular channels, but an eXtra 20 channels or so that you can only get online or on a new 2.0 radio. Let me know how it works out for you. Regards, Engineer Scott
Jun 06, 2014 | Clarion (NAVSIR) SIRIUS Radio Receiver
My 2008 Ford Edge cannot seem to hold the Sirius signal. It works intermittently. For no known reason I lose the signal. (No Signal) I have called Sirius and they have sent an activation signal and it...
I had a similar problem. Tune your sirius to 184, leaving the radio and the key on with the drivers door open. Let set for 15 minutes. Before you do this procedure, call sirius to tell them to send a boost to your radio. This should take care of your problem. Good luck :)
Nov 18, 2010 | Ford Edge Cars & Trucks
"Powering Down" Problem on Sirius SUB-X1 Universal Boombox
The power srouce is usaly locate at the back of the stero.. if it isnt.. its at the bottom. I would als try pluging it in.. and leaving it for a dayu... becuase maybe it charges
Dec 26, 2008 | Sirius SUBX1 Universal Plug and Play Boom...
Stiletto constantly powering off
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
Dec 26, 2007 | Sirius STILETTO 100 MP3 Player
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
Receiver CRSR-10 not powering fully on
GREGG, HAVE YOU TRIED TOSSING SIRIUS OUT THE DRIVER'S SIDE WINDOW AND TUNING IN A.M.? IT WORKEDS FOR ME GRUMPA
Sep 28, 2006 | Sanyo CRSR-10 SIRIUS Radio Receiver with...
 Grubhead
Grubhead
