Question about Maytag Neptune MAH6500A Front Load Washer
Can i reverse the door on my maytag neptune washer MAH6700AWW
Amigaman
  • 248 Answers
SOURCE: maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Posted on Oct 21, 2007
  • 20 Answers
SOURCE: Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Posted on Jan 19, 2009
ginko
  • 19396 Answers
SOURCE: I want to repair the washer door boot on my maytag neptune ?
Here you find alll diargams for your appliance.
Posted on Feb 06, 2009
aborcass
  • 2651 Answers
SOURCE: I need a diagram for a maytag neptune mah5500bbw washer
here you go!
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Posted on Mar 20, 2009
  • 1294 Answers
SOURCE: Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
Posted on Mar 26, 2009
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Mar 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH6500A Front Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
