Question about Fuji Office Equipment & Supplies
Forgot my password for docuprint cm305 df
Forgot the panel password machine can't operate, panel lock
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
Locked out of my computer
Which Password? Bios Password?Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista?Windows 7?OK,if you are running Windows 7, Microsoft tightened security on it so you've gotto have a password reset disk which 99% of the people who own laptops withwindows 7 fail to do. It should be one of the first things you do whenyou buy the laptop. Otherwise, you're faced with reinstalling theOperating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator(hopefully you didn't put a password on it and forgot it too). Once thedesktop appears it will look different, the screen will be darker and the iconsbigger, but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Jun 07, 2012 | Computers & Internet
I locked myself out of my laptop, how can i unlock it
Jun 03, 2012 | Computers & Internet
How do I unlock I locked myself out of laptop unable to login
May 08, 2012 | Gateway Computers & Internet
Need to bypass masterpass word
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
May 08, 2012 | Computers & Internet
Locked password
Locked Password where? Bios Password? Hard Drive Password? Windows User Account (userid) Password? And which operating system?
If it's the Bios Password, then you will need to remove the CMOS Battery and let the computer sit for a couple of hours. Then put the battery back in and try rebooting. You'll have to go back into the BIOS or Setup to put the correct date and time in but the password should be gone from memory.
If it's the Hard Drive Password, you're kinda out of luck. Hard drives are locked 99% of the time when the computer is stolen. The original owner either locked it while he had possession of it or he could have locked it remotely when it was stolen to keep thieves from getting to sensitive data. The only way around it is to have the original put the password in, or Purchase a new hard drive to put in the computer, reload the operating system, reload the drivers and reload application programs.
If it's the Windows Password for User Account turn off the computer, then turn it on and immediately start hitting the F8 key until you see the SAFE MODE Option. Take the Safe Mode option to boot the computer. When it comes to the login screen it will show you the Administrator account and the Account for which you forgot or don't know the password. Log into the Administrator account (hopefully you didn't password protect it and forgot it). When windows desktop comes up click Start/Control Panel/User Accounts. When the User Accounts window opens up click on the User Account for which you forgot the password then select Remove Password. Reboot the machine
Mar 17, 2012 | Computers & Internet
Fuji Xerox Docuprint CM305df user manual
I have a Fuji Xerox CM305 df, it raised an alarm to Replace Transfer Unit, I've replaced that but the alarm/message is still active, how do I go about now??
Feb 21, 2012 | Fuji Office Equipment & Supplies
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
134 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
