Question about Samsung Ts220w Thin Client Embedded Windows Led Lcd
Samsung Ts220w change hdd - Samsung Ts220w Thin Client Embedded Windows Led Lcd
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Samsung HDD smart hub has Netflix app installed but it wont launch Netflix. It reports an error , referring to Netflix/help. Can you advise how to solve this?
Hi there
where in the world are you? Netflix is not supported everywhere.
I used to have to go through the process of changing IP addresses and DNS numbers. I always get useful information on Please select your language
best of luck
kolbrun
May 09, 2016 | Samsung Computers & Internet
How to change, bypass, the HDD password on Samsung Model NP 300E5E
Samsung bios password removal - YouTube
? 0:48
https://www.youtube.com/watch?v=QSiUFFWQUOI
Oct 3, 2010 - Uploaded by ScruffyLionTv
Hey guys this is a password removal service free of charge just ... maybe the password is changed, becouse i remove hdd from laptop, ... Samsung Model No: NP300E5C-A011N SN No. ....Samsung NP-R519-JA06ZA 01921269501D289221 .... How to:Samsung Q310 BIOS Password reset / clear cmos ...
Nov 19, 2015 | Cars & Trucks
Unknown device
Samsung HDD division was only recently sold to Seagate.
"ST" is a Seagate number so your drive cannot be old - manufactured by ex-Samsung factory now part of Seagate.
Utility from Seagate (e.g. Seatools) should be able to display from S.M.A.R.T the number online hours.
Dec 27, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
I need to know the jumper setting for my hard drive to set it to a slave
Here is the jumper settings for Samsung hard drives. Assuming that your hard drive is bigger than 32GB you have to use the "General Pin Setting"
Note that after changing the jumper, it's suggested to partition and format your hard disk drive.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Samsung Computers & Internet
Samsung R65 HDD not detected in bios
Chances are that your HDD is on it's way out the door; even if you get it to come up on another computers via USB adapter. There could be issues with your motherboard, but a faulty HDD is more likely. The only way to be sure is to put another HDD into your computer to see if it shows up or not. If it shows up, then that pretty much affirms that your current HDD is going bad. See MADHATTER COMPUTERS.
Mar 20, 2010 | Samsung R65 Notebook
How to upgrade hdd for Samsung DVR HR737
If you want to play your videos from your computer to your dvd the best way i have found is download realplayer when its downloaded and your ready to go. Go to burn and transfer cd in the options on the burn page at top it lets you change formats.The format you need to use to go from computer to DVD player is vcd it has a DVD format but i don't have a DVD burner so i haven't tried that format yet.Hope this might help.
God Bless Greg
Here is address: http://www.real.com/ i use the free and it works great
Nov 11, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Hdd failure
It is not smart to switch a IDE with a SATA,
it should be IDE with IDE and SATA with SATA
Each transmit diffrent levels of instructions.
The clicking is definitely not a good thing. It means you nearly shorted something out to the point where its not sending the correct impulses in power. Most likely the hard drive might be able to work. but the clicking means its blocked or somethings preventing the head from moving or doing what its supposed to do. You will need a new Hard Drive.
My recommendation is to send your old HDD to have it recovered in a clean room if you want your data from it. or replace board with like board, being exact. other wise switch the board and have a high level format for the clicking. Its the only real way to fix a HDD, but its not worth it for the cost that you will be charged. Your better off buying a new HDD
Aug 09, 2008 | Samsung SpinPoint V80 SV1203N 120 GB...
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Samsung Ts220w Thin Client Embedded Windows Led Lcd Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
