Question about DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
Plug it on the socket but it does not turn on
How change spark plugs
Have a look on the following link for the socket/wrench/tool you will need:
spark plug socket Google Search
To avoid getting the ignitions leads replaced in the wrong order:
Remove ONE lead from ONE plug at a time.
Use the tool/socket to remove that plug by turning anti-clockwise.
Put the new socket in hand tight - this is to avoid cross-threading the spark plug and damaging its threads/threads in cylinder head.
When the spark plug is hand-tight/finger tight, tighten it with the socket /tool. Just 'gently tighten it up' - do not overtighten.
Replace the ignition lead and then move onto the next plug.
removing spark plug Google Search
Feb 10, 2016 | 2005 Ford F-150
How do i replace spark plug
Without more information, like make and model, I'll have to give you a generic answer:
1. Unplug the plug wire from the plug
2. Place a plug socket over the plug
3. Use a socket driver to un-screw the sparkplug
To reinstall:
1. set the new plug's gap to the manufactures recommendation.
2. Lubricate the threads of the new plug with lithium anti-sieze grease (lightly, an amount the size of a grain of rice is plenty)
3. Hand-thread the new plug in as far as you can hand-turn it.
4. Put the socket wrench on it, tighten no more than 1/2 to 3/4 turn after the gasket contacts the head.
5. Replace the wire on the plug's top.
On some cars, the space to get to the plugs is very limited. I've changed plugs where the plugs were between the exhaust pipes, or behind the alternator.
Jan 17, 2015 | Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
On a 2012 freightliner cascadia, how do you change the front turn signal bulb?
The socket the bulb plugs into must be turned to the right (as if it is reverse threaded), then the bulb and socket will release. The bulb itself is simply plugged straight in, so simply pulling straight on it should remove it from the socket. Then, press the new bulb (#4157NA) firmly into the socket until you feel it "click" in, and reinsert the bulb/socket assembly back into its housing and turn it to the left until the socket "clicks" to lock it back in place.
May 17, 2012 | 2012 Chevrolet Silverado 1500 Work Truck...
How do you replace spark plugs.
One spark plug at a time. Use a 3/8 extension and a spark plug socket, the socket should have a piece of rubber in it to hold the spark plug in it. Remove the spark plug wire to gain access to the plug, then using the socket and rachet with the extension, turning to the left untill spark plug is all the way out. Looking at a spark plug can tell you several things about each cylinder they come from, so get a manual for your car, anyways replace new spark plug in the socket, be sure to double check the right gap, then replace by turning to the right/clockwise direction untill it is snug in the hole. Do not over tighten or under tighten. Replace the sparkplug wire and move to next plug. Good luck
Feb 21, 2011 | Lincoln Aviator Cars & Trucks
Just bought 82 el camino cant change last spark not enough room for deep dish socket behind header do they make a special tool?
sometimes it the socket u use,,some are thicker then others,,,try a thin wall socket;;;or a regular socket on a spark plug one
Feb 02, 2010 | 1982 Chevrolet El Camino
How to change spark plugs - what order do I connect the plugs in
Get a 3/8" drive ratchet with an extension and a 5/8" spark plug socket, doesn't matter which one you take out first, take off plug wire, slide socket over plug, turn counterclockwise to loosen, take plug out of socket, place new plug in socket, insert plug in hole and turn clockwise to tighten, put plug wire back on. Do one at a time and you can't screw up the firing order.
Dec 20, 2009 | Nissan Hardbody Cars & Trucks
Where is the radiator drain plug for a oldsmobile alero 2001
The radiator drain plug is on the lower left front (drivers side) of the radiator. To access it you may have to remove the front air dam. It is a white plastic plug and requires a Torx socket to loosen (sorry but not sure of the exact size of the Torx socket). Insert Torx and turn counter clockwise a half turn. Pull the plug out using a pliers until fluid begins to drain. Be careful because this is a plastic plug and may break easily. When fluid is finished draining simply push the plug in and turn clockwise half a turn with the Torx socket to secure.
Oct 12, 2009 | 2001 Oldsmobile Alero
Spark plugs
Wait until the engine is cold. Carefully remove the spark plug wires from each cylinder. Pull the wires by the boot and not by the wire or the wire will be ruined. Now, using a spark plug socket (one that has a rubber fitting inside of it) and an extension remove the spark plugs by turning the wrench counterclockwise. Insert the new plug into the socket so that the rubber will hold the plug in. Place the plug and socket down inside of the hole. Hand tight the plug by turning the extension clockwise. Once the plug cannot be turned by hand, tighten it a little more with the socket wrench. Install the wires back onto the plugs by pushing down on the boot. thanks for using fixya and plsase do rate the solution.
Jun 12, 2009 | 1993 Saturn SC2
DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater Logo
56 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
