Question about Asko Dishwashers
Asko diverter valve
Replacement
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: How can I replace a diverter valve?
go and download www.fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on Jun 22, 2012
How do you replace the diverter
You have probably replaced your diverter valve by now. I purchased a new valve for about $14.00. It took me about 30 minutes of swearing under the sink to replace it. See instructions on the Price Pfister web site. See the video about cleaning the diverter valve.
Aug 06, 2014 | Price Pfister Plumbing
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
Asko d3152
not on any model ive ever seen. the supply tube that feeds the arm or the arm itself may be clogged with food particles preventing it from achieving the neccessary pressure.
Sep 26, 2013 | Dishwashers
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Pumps out instead of recirculating
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
God bless you
Jun 21, 2012 | Asko D3251HDSS Stainless Steel Built-in...
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
29 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
