Need to reset printer settings for brother hl217w
There is no option to reset under machine info
I Suggest You To Watch
How do factory reset the network settings Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On:- Brother Printer Support
Oct 03, 2011 | Brother DCP9045CDN
Tip
Reset all models of Brother Printers
<p>Applicable for all models of Brother Printers. Sorry, I still not yet tried this method because very difficult to get Brother Printer, this is possible cause of the printer is not popular printer. For everyone that having Brother Printer, I hope this post can assist your.<br /> <ol> <li>Disconnect the power cord from your Brother Printer. <li>Press Set button, while holding the Set button re-connect the power to your printer <li>The Error code will be display "Machine Error 46&prime; <li>If the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display. <li>Choose 8 then press Set Button <li>Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode. <li>Press "Mono Key/Button" 25 times or until "Purge Counter Appear" <li>Now press arrow up (^) again then choose "2&prime; press Set Button <li>Press Arrow Up (^) again then choose "7&prime; press Set Button <li>Press Arrow Up (^) again then choose "8&prime; press Set Button <li>Press Arrow Up (^) again then choose "3&prime; press Set Button <li>The purge counter will be reset to Zero. <li>Now Press Stop/Exit Button <li>You will return to Machine Error 46 <li>Press Arrow Up (^) then choose 9 press Set Button <li>Press Arrow Up (^) again then once more choose 9 press Set Button <li>Your Printer will reset then wait until it power up again. </li></ol>
on Mar 08, 2011 | Office Equipment & Supplies
RESET SETTING FOR PRINTER BROTHER MFC-260C
Steps in resetting Brother printer...
Disconnect Brother Printer from power cord. Press Set button and while holding the Set button re-connect the printer to the power cord (electric source). It will display an error message "Machine Error 46? on the LCD After the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display. Choose 8 then press Set Button Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode. Press "Mono Key/Button" 25 times or until "Purge Counter Appear" Now press arrow up (^) again then choose "2? press Set Button Press Arrow Up (^) again then choose "7? press Set Button Press Arrow Up (^) again then choose "8? press Set Button Press Arrow Up (^) again then choose "3? press Set Button The purge counter will be reset to Zero. Now Press Stop/Exit Button The printer will return to "Machine Error 46? again Press Arrow Up (^) then choose 9 press Set Button Press Arrow Up (^) again then once more choose 9 press Set Button The Printer will reset then wait until it power up again
Hope this help!
Sep 06, 2011 | Office Equipment & Supplies
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  3. Enter the print server password (The default password is "access").
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
  6. The print server will then reset back to its default values.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
Brother MFC-425CN...ERROR MESSAGE READS...UNABLE TO CLEAN...TRIED EVERYTHING IN MANUAL????? WILL NOT SCAN OR PRINT...OR TEST PRINT ETC ETC...
You need to contact brother regarding that error message. It simply means that your printer's purge counter is full and you just need to RESET it to ZERO. I already have a post regarding this "unable to clean" error but it is for Brother DCP-150C. I also got it from a Brother Tech Support. So I think the commands in my previous post is different since you've got a different model. Better ask a Brother Tech Support for the procedure in resetting the purge counter.
Anyway, this is the post, if the sequence is right for your device, then this will work:
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET/OK
b. 0 then press SET/OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET/OK
b. 7 then press SET/OK
b. 3 then press SET/OK
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET/OK
b. 1 then press SET/OK (To reset unit)
a. 9 then press SET/OK
b. 9 then press SET/OK (To exit Maintenance mode)
Dec 27, 2009 | Brother MFC-425CN Multi-Function Center...
We installed a new fuser into a Brother HL4200CN (Fuser FP-12CL) and it came up with "ID Error for Fuser" Is this a defective fuser or were we suppose to reset a code somehow? Thanks
This message appears when the printer cannot recognize the fuser - probably because you haven't reseted the counter. Make sure it's properly installed. If it is then you will need to perform the reset procedure
1. Press Additional Functions Key
2. Press # key
3. Arrow to number 7, Printer and press Set
4. Arrow to number 4, Printer Re-Set and press Set.
5. Press Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Jan 27, 2011 | Brother HL 4200CN Laser Printer
How to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
May 21, 2009 | Brother HL-5270DN Laser Printer
Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Mar 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Mfc-115c brother printer
there is no "reset". If you have done settings within the maintenance mode, the settings will be kept!
Mar 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
