Question about Gigabyte Computers & Internet
F2A55M-DS2 computer wont start after bios flash
  • Gigabyte Master
  • 9,587 Answers
Try reflashing the BIOS again.
Posted on Nov 22, 2016
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: how to change bios setting on GA-F2A55M-DS2 motherboard to install XP
The BIOS should not prevent you from installing Windows XP.
If your hard disk is a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Posted on Feb 25, 2013
F2A55M-DS2 vista display drivers
Try downloading the latest drivers from AMD's website, found here:
http://support.amd.com/en-us/download
You can use AMD's auto detect program to find the best match.
If you're using a video card plugged into the PCI-E slot to display your graphics, I'd recommend disabling the onboard video by accessing your computers BIOS/EFI by pressing the right Function key on startup. If the graphics card you're using is AMD, the above link will also find the correct driver to use with it.
If it's a Nvidia based card, try their site for drivers, located here:
http://www.nvidia.ca/Download/index.aspx
Hope this helps!
Aug 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
Pentium 4 motherboard map
here is the rig i suggest for a good upgrade (300 euros, 350 dollars probably) :
AMD a6 5400k BLACK edition apu (means it has built in graphics card 7540D) .
motherboard: Gigabyte F2A55M-DS2
HDD : Seagate SATA3 ST320DM001
RAM: Corsair single rank 2gb (x3 or x2)
and PSU: Bitmore silent power 450W
(You choose case and optical drive, at an extra cost)
Thanks for using fixya!
May 13, 2013 | Computers & Internet
How to change bios setting on GA-F2A55M-DS2 motherboard to install XP
Feb 24, 2013 | Gigabyte Computers & Internet
Flashed bios now computer wont run
Flashing a motherboard's BIOS can have many positive purposes and can help keep a motherboard compatible with changing technology. PCnineoneone.com says that a proper BIOS flash can introduce enhanced features and bug fixes for the motherboard. However, a bad BIOS flash can be devastating to a computer owner and very difficult to recover from. If the proper preparations are made and all instructions are followed, a bad BIOS flash can be corrected.
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back. Remove the jumper from its normal position on the motherboard and place it in the recovery position. Usually, the jumper will need to be moved over one space to cover a previously exposed prong. Locate the BIOS CMOS jumper on the motherboard, usually in the bottom, right corner. The jumper consists of three metal pins facing upward and is usually marked with "CLR_CMOS" and has a plastic cap over two of the pins. Check your specific motherboard manual if you are unsure where the jumper is. If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect. Insert the BIOS flash disk and power on the computer. If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer. Since there will be no video, listen for the internal PC speaker to beep. This means it is performing the BIOS upgrade. Power down the computer once the BIOS upgrade has been completed. This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished. Without video, the only way to be sure is to listen to the PC speaker. When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off. Replace the jumper back in its normal position and put the side panel of the computer back on. Power the computer on. If the computer turns on as normal, the recovery was a success. Hope this helps
Jan 20, 2013 | E-Machines eMachines Desktop PC
H61m-ds2 motherboard wont stay connected to internet
If you computer lock up, because your motherboard does not getting enough power ? or your memory is bad ?
Aug 29, 2012 | Intel Computers & Internet
PATA boot problem
Did you set the boot options to boot from the PATA drive? Did you set the port mode to legacy IDE? Did you try to let the BIOS determine the type of drive?
Jul 02, 2009 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Black screen after BIOS update
better flash the bios again, this time try a different version of the bios. but, if it wont boot from the new bios flash disk, then u just turned your computer into a paper weight.
Dec 29, 2008 | NEC Computers & Internet
Bios update
Hi ber2zo,
As long as you follow the directions there should not be a problem. Gigabyte does explain how to flash & back up the bios with Introduction site.
http://www.gigabyte.com.tw/Support/Motherboard/Utility_Model.aspx?ProductID=2427
Read the warning & get bios file here.
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=2427
Never update a bios if the new bios file does not fix an issue.
Good Luck!
Mike
Jul 04, 2008 | Gigabyte GA-945GME-DS2 Motherboard
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Open Questions:
Computers & Internet Logo
115 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
