Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Can i buy the locking mechanism for a non-locking pedestal
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Apr 18, 2015 | LG Washing Machines
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
Car continues to ding even though seatbelts connected and doors are all closed
The door micro switches that also serves a housing for the locking mechanism have either failed or are stuck or worn out. This switches tells the ECU if the door is open (courtesy door light on) or off. It can be replaced buying the whole mechanism (VW OEM Part) or replacing the micro switch with equivalent switches (Non VW Part).
Sep 08, 2013 | 1999 Volkswagen Beetle
Kitchenaid stand mixer K45SS willnot tilt the head I do not understand How to fix this problem
Put a towel on the bench and put it upside down on the towel. Wriggle lever and pedestal about and it may free up. The lever may be disengaged from the locking mechanism. The machine will need to come apart to fix any mechanism lever problems.
Aug 16, 2013 | Food Mixers
I need a pedestal stand for an LG 47" FULL HD,
Tries websites like Amazon.com,Ebay.com to buy an a used or new LG pedestal stand.
Nov 06, 2010 | LG Televison & Video
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
Replacement kenmore pedestal front drawer cover?
The pedestal should have it's own model number on it. Find the model number and contact Kenmore parts depot and they should be able to get you a front panel.
Dec 26, 2008 | Kenmore 15.5 in. Pedestal
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
