Bush LCD40883F1080P. When the set is switched on via remote the light flashes once then goes back into standby. Any ideas please ?
Set was working perfectly but when left on standby over night it now refuses to turn on. Indicator light flashes once then it goes back into standby.
alltechserv.
  • 32 Answers
SOURCE: idlcd32tv27hd comes on for 1 second then goes to standby
REPLACE 2-4 BULGING CAPACITORS IN THE POWER SUPPLY BOARD, PLEASE LET ME KNOW IF FIXED. THANKS
Posted on Mar 15, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Standby lamp flashes
if the lamp light is flashing,remove the lamp and check it there is 98% of possibility that is bad.
Posted on May 20, 2009
  • 8457 Answers
SOURCE: Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Posted on Sep 05, 2009
  • 117 Answers
SOURCE: Switched to standby red indicator light flashes.
dear user ,
the capacitor of supply board is weak.kindly replace the capacitor. the sign of defective capacitor is that its swell form upper side.
Posted on Feb 04, 2011
bugoy31
  • 1238 Answers
SOURCE: My bush lcd32tv009hd wont turn
Good day!
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.Please don't forget to rate my answer.
Posted on May 09, 2011
Testimonial: "thx for that will try it later"
I have a Bush 31 inch smart tv and it switches itself on and off but when Its off red light keeps flashing and i cant use the remote please help im getting frustrated
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Aug 31, 2015 | Bush Televison & Video
Bush hd tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Televison & Video
I have been given a Bush B320DTR, without a manual, connected it and was working fine, set it to record a few things then put it on standby, now cannot get it machine to switch on, the sticky label says...
Sometimes simply unplugging the unit from the mains will solve this problem. Are there any lights showing on the recorder when plugged in? We stock the Bush B320DTR at GoGoDigital - if you want a copy of the manual please do email us at helpdesk@gogodigital.co.uk
Jun 05, 2012 | Televison & Video
May 19, 2009 | Initial HDTV-320 32 in. LCD TV
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
Nov 05, 2008 | Bush 5693D 24" TV
Stuck in Standby
change the horizontal output transistor .its busted.
Aug 14, 2008 | Bush 5693D 24" TV
Bush digital terrestrial receiver dfta 11
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Mar 09, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
