Question about Canon imageRUNNER 2270 Copier
Where do i find the ip address on my canon irc2380/2550
2 Suggested Answers
  • 108 Answers
SOURCE: How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Posted on Nov 25, 2009
Testimonial: "Thanks, Can you please advice how do i print network setup page from this printer [Cannon ir3570]"
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
What is the ip address?
An ip address is the address assigned each device in a computer network. For example, a common ip addresses for a home network are 192.168.1.1 through 192.168.1.10. Each device on the network will have a different ip address.
Good luck,
Paul
Jan 25, 2016 | Canon iP100 Portable Printer
I need to find the ip address of the Canon Pixma MP480 printer I want to install. I have downloaded the software but need the ip address
If you cannot find it on the printer, your next best option is to log into your internet router if you have one and check the assigned addresses in the DHCP list.
Sep 12, 2015 | Canon PIXMA MP470 All-in-One Printer
Ip address
Click the Menu button on the printer and scroll to the Network settings to the IP address. You may need to change the IP address to suit your network.
Feb 26, 2013 | Canon MultiPASS MP360 All-In-One InkJet...
I need gateway address, subnet mask and TCP/IP Address for canon irc2620n
IP Address: 245.36.4.25
Subnet Mask: 255.255.0.0
Gateway: 245.36.0.1
If fail suggest to set iRC2620N to DHCP so that your DHCP server or router to assign a TCP/IP address.
http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/color_imagerunner_c2620_c3200_c3220/color_imagerunner_c2620_c3220
Dec 17, 2012 | ASUS K53e A1 Notebook
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' eHow.com http://www.ehow.com/how_7427700_set-canon-imagerunner-210-n.html#ixzz19ZSyEw8N Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
Dec 16, 2009 | Canon imageRunner C3100 Copier
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
Setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
Canon imageRUNNER 2270 Copier Logo
102 people viewed this question
old marine
old marine
