Question about Freestyle Watches Freestyle 101179 Killer Shark Touch Mens Watch
How do I set the shark 101179 watch? I can't push the plastic tabs on the side of the watch.
I opened the package and dont know how to turn it on!
mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
Jun 17, 2011 | Watches
Need to change battery in EH23sa
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Mar 21, 2011 | Watches
How do I remove links from geneva wrist watch band
Take a small hammer and a plastic push pin. Look at the pins in your watch. One side will have a line going through the tip of the pin, and the other side may also have that, but it will be less pronounced. Set your watch on a soft surface (couch cushion or cork board, for example) and place the pushpin onto the pin you want to remove. Tap with a hammer until a few millimeters are sticking out on the other side. Take a pair of needlenose pliers and remove the pin. To put a pin back in the band, push it back in until you cannot push anymore, then use your needlenose pliers to push the pin in the rest of the way. Good luck!
Oct 05, 2010 | Geneva J06345 Wrist Watch
New watch - how to start it - battery?
mcdevito75 here, Brand new watch. If it has a stem, (winder) look for a small piece of plastic between the stem and case, remove this piece of plastic and push down the stem to start your watch. If your watch is all buttons, look for a small plastic tab on the back cover, remove this plastic tab and your watch will start.
Sep 20, 2010 | Adidas Response Light Twin watch #ADP1701...
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
Hello, this may sound silly but I just bought a Timex Ladies watch and I can set the clock but it's not actually turning on when I push the side button in? It's a new watch direct from Timex so I...
mcdevito75 here, A brand new Timex quartz watch will come with a small piece of plastic just under the crown to keep the battery form working the watch, simply remove this small piece of plastic from under the stem (winder) push the stem in and your Timex will work. If your timex is push button you may have to hold down the Mode 2--3 seconds to see display.
Aug 02, 2010 | Timex 27191 Wristwatch
I just got a Freestyle Tide Watch 3.0 for Christmas. I set the alarm, and now I don't know how to turn off the alarm. It only seems to give me the option of which days I want the alarm to go off, no...
I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
Dec 26, 2008 | Freestyle Shark Tide Data 4 Alarms All...
How do I release the battery clip on a Timex Expedition watch to change the battery.
I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
Good luck.
Jul 20, 2008 | Timex Watches
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Freestyle Watches Freestyle 101179 Killer Shark Touch Mens Watch Logo
19 people viewed this question
Top Freestyle Watches Watches Experts
Jimmy Accardi
Are you a Freestyle Watches Watch Expert? Answer questions, earn points and help others
