Question about GE JES1142SJ Microwave Oven
Change light bulb in general electric jes 1453
Light blub change how to
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Where is the light bulb located?
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Posted on Jun 29, 2008
CHANGE THE BULB
Remove the top grill assembly. It is usually held on by 2 screws going down through the cabinet top. You may need to tap the grill to the left slightly to get the tabs to release. Once the grill is off, look near the middle of the top edge of the microwave frame for 1 screw that looks like it goes through a metal lip. It will be right above the inside light bulb area. remove screw and then pull the metal tab towards you. The complete light bulb assembly will slide up and out towards you. Replace bulb and reassemble microwave.
Mar 01, 2015 | General Electric GE Profile SpacemakerR XL...
Replace inside light bulb
gonna needa open it up theres about 6 screws holding the covere and it like a small light blub u can uncrew it or if not it has a has a clip u pull off and are able to change it
Oct 13, 2014 | GE Spacemaker JVM1750 Microwave Oven
How do I change the light bulb in a JES 1451 ?
On this model, it's not meant to be a user serviceable part.
You would have to remove the outer cover, and then the light bulb is located on the air duct attached to the magnetron on the right side of the innards.
You can find helpful exploded views and order the bulb assembly from the Pros here.
Enter your full model number from the tag with suffix and no spaces.
See these help files on safety and disassembly first.
Nov 30, 2012 | Microwave Ovens
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2012 | General Electric PVM1870SMSS Microwave...
I have a GE JES 1855 Microwave Oven, my light bulb burnt out there is no instructions telling you how to replace the bulb!
You have to take the out side cover off and there you will see how to change the bulb.
Jul 03, 2011 | Microwave Ovens
GE microwave JES 2251 SJ02 Light bulb that illuminates oven interior burnt out. Have correct replacement bulb (I think!). Can I remove oven cover and replace light bulb while keeping a good distance away...
sTEVE, THE CAPACITORS HOLD A CHARGE EVEN AFTER THE SYSTEM IS UNPLUGGED. A good rule of thumb would be to allow at least 48 hours for the capacitors to discharge before even getting nea them. Then, yes, you can replace the bulb. Thanks
Jan 27, 2011 | GE Microwave Ovens
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Change light on a ge convection microwave
If you can change the bulb there will be some screws on the outside at the back. On some models however you cannot replace the bulb.
Jun 06, 2009 | General Electric Microwave Oven
Light in convection shorted out when replaceing blub
This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb.
This is a problem with the control panel assembly, which we repair nationwide for $39.95.
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams by entering your model number here: http://tinyurl.com/gv383
Oct 09, 2007 | GE JEB1095 Convection/Microwave Oven
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
GE JES1142SJ Microwave Oven Logo
37 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
