Question about KitchenAid Ovens
My KITCHENAID KEMI371 oven is dropping black metal
2 Suggested Answers
cadillac02
  • 318 Answers
SOURCE: i am seeking a operators manual for a oven Model #
Here's the link. You are missing the last four of the model number. Locate it and match it to the list at this link and you can order the manual.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KEMI371
Posted on Feb 04, 2011
I need a kitchenaid superba manual freestanding electric oven manual model number KERC607HWH0
Kitchenaid has manuals for most of their appliances on their support web site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Enter the model number and the type of customer you are (consumer) in the drop down menu and click on Go. The direct link to the manual for the KERC607HWH0 electric range is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209753846.pdf .
I hope this helps.
Oct 19, 2011 | Ovens
I am seeking a operators manual for a oven Model # KEMI371 TVLQ ser # 1201176?
Feb 04, 2011 | KitchenAid Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Kitchenaid Conv OvenHeating to toast grilled cheese
At higher temperatures, glass expands differently to metal. if glass was installed tightly by what ever means (some use silicon sealer or metal clips etc.) the different expansion rate could have been the problem. Not to mention a possible weakness in that piece of glass.
Sep 14, 2009 | KitchenAid Architect Series KEMC308KSS...
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
Wiring in oven
If you are saying you are re installing this oven, then what did the 2 other wires go to before?
Feb 15, 2009 | KitchenAid Ovens
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Ovens Logo
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
