Question about Crosley Washing Machines
Crosley cw7500w makes noise when stopping
Squeeking or grinding noise when spin cycle stops
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 10 Answers
SOURCE: washer make a grinding noise in the spin cycle; barrel does not spin in spin cycle
check the transmission out or it can be a clutch problem
Posted on Dec 14, 2007
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • 40 Answers
SOURCE: Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Posted on Mar 10, 2009
My Crosley CAW8350EW1 wash machine just stopped after the last spin cycle drained and the spin light keeps flashing. I'm wondering if that would be the timer or something else?
make sure that it didn't stop because of an unbalanced situation
as it is draining it should be turning slowly and as soon as it empties the spin speed picks and and the unbalance stops the machine
Mar 14, 2017 | Crosley Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
My dryer is making a horrible noise when turned on and then when the cycle is stopping. the noise continued to happen then began going through the whole time cycle. The dryer is getting hot but it is not...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 17, 2011 | Crosley CDE6000 Electric Dryer
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
The machine made a slight squeek noise each time it slowed down and then started up again (durring the wash cycle) We also noticed a strange odor. It was almost a asbestos burning type of smell. Then later...
It probably mean the spin brake has failed. If everything else is functioning OK and it is not making anymore strange noises it will be OK however when you open the lid(during spin) if it takes more than 10 seconds to stop then the brake should be replaced. If you need anything else please let me know.
Mar 19, 2010 | Maytag Washing Machines
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Mar 09, 2009 | Washing Machines
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
