Question about Honeywell 17000 Air Purifier
Honeywell 50250 fan won't run - Honeywell 17000 Air Purifier
Looking for a break-down / exploded view of a Honeywell Air Purifier, model HFD-120 ?
Honeywell Air Purifier - problems - YouTube
? 1:22
www.youtube.com/watch?v=gWB121JIQMw
Apr 28, 2011 - Uploaded by Bill Golden
Overview of damage and possible fan problem with Honeywell Air Purifier. ... Honeywell QuietClean Compact ...
Oct 03, 2015 | Honeywell Air Purifiers
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Feb 21, 2011 | Honeywell Enviracaire 13520 Air Purifier
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Hi my old Honeywell 13520 has acquired a periodic squeal. I am sure it is a motor issue. Any way to tune up these little motors? (Brushes, etc..)
Usually if the motor is squealing, the bearings are dry no lubrication and worn. If you have oil ports you can oil it and quiet it down for a while. Most motors now have self lubricated or oil impregnated bearings, which you can't lubricate. It costs as much for somebody to replace the bearings, as it does for a new motor. Most people replace the motor.
Nov 17, 2009 | Honeywell Enviracaire 13520 Air Purifier
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
How to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Feb 18, 2008 | Air Purifiers
Honeywell 17000 Air Purifier Logo
76 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
