Question about Acer Computers & Internet
Trying to connect iqon monitor to laptop...no input signal
    Problem Solver:
  • 20 Answers
In control panel select display and select 2nd monitor as default
Posted on May 01, 2014
2 Suggested Answers
ceezer
  • 20 Answers
SOURCE: how to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Posted on Jul 08, 2008
External monitor has no input signal
You can't just attach an external monitor to most running laptops. Nothing will happen. You must attach the monitor when the laptop is off, then start the laptop and it will recognize the external monitor and send the video to it.
Feb 13, 2014 | Compaq Presario CQ56-115DX Laptop
Iqon external monitor showing no input from Compaq laptop
Dear Darren,
In general, you need to select which output display to use, when you have more than one display connected to the laptop.
This can be done by pressing and holding the fn in the lower left hand of your keyboard and then pressing F4. Doing this repeatedly will switch from the laptop display to the external display to image on both displays.
Hope you may find this information helpful!
Best regards,
Miguel L. Martins
Iqon no monitor
check external monitor through vga
Feb 13, 2014 | Compaq Computers & Internet
No Audio on external device via VGA
Dear Paul,
VGA cables have no provision to carry audio signal - they only carry video signals.
In general, external monitors that also have speakers have RCA-type or miniplug-type audio inputs. In this case, you will need to use another audio cable to connect the phones output of your laptop to the input of your monitor, using a suitable cable.
If you provide us the model number of your laptop, as well as the one for your external monitor, we could try to find the info regarding the kind of audio cable needed to connect both.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
Feb 01, 2014 | Fujitsu LifeBook Computers & Internet
No input monitor signal
Sounds like the video card inside the computer is bad. If the monitor was bad it would not be able to display the No Input Signal. To make sure, try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same No Input Signal message then your video card is bad. If the Borrowed monitor displays and works ok, then your original monitor or lcd screen is bad.
If you have a laptop, The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Foxconn (M61PMP-K) Motherboard
My iqon desktop pc monitor and tower will not connect it juct says no signal
See my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
You will need to bring it back to life jasonlax
Follow the guide!
Take care!
damnor01
Apr 16, 2011 | Computers & Internet
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
Monitor goes into sleep mode...mentions no input ........tried rebooting and turning off power with no luck..then replaced cable connecting monitor to computer and still not working...
Connect the monitor to another computer (laptop?) to see if the monitor works at all.
Try connecting another monitor to your computer, to verify that your computer is emitting the correct video signals.
Jan 01, 2010 | HP Computers & Internet
My monitor gets no input signal, computer does
Try the montor on the external vga connection of the laptop. You can swap the signal from the laptop screen to the external monitor using the swap key (usually a FN key). You can do this whilst the laptop is up and running. If you see the display there, then you know the monitor is o.k. Then check the connection to the PC. If it is a card (PCI/AGP) make sure the card is properly seated. If you don't see display on either check the pins on the monitor plug if any are bent or missing. Sometimes these pins can be accidentaly pushed back into the plug housing. You can retrieve them with small long-nosed pliers.
Sep 16, 2009 | Xerox XA7-17i 17" LCD Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
