Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Switch for self propelled doesn't work
Can't get self propelled to work
reddevil6
  • 1673 Answers
SOURCE: U6439-900 Self Propell on/off switch
Check the cable to see if it is broke either in the handle or down below, you can see it from the top . If it isn't broke, the part that the cable hooks to (actuator)may be broke. Could be the flat belt, they stretch after awhile and will just slip and drive the transmission or brush roll under load.
Posted on Apr 20, 2008
  • 175 Answers
SOURCE: Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Posted on Nov 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 17, 2010
  • 240 Answers
SOURCE: just put handle on windtunnel
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Posted on Mar 18, 2011
murf427
  • 336 Answers
SOURCE: self propel switch is broken
Most large towns have repair and part supply stores for vacuum cleaners. You can order your new switch there.
murf427
Posted on Aug 03, 2012
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
Self propel switch is broken
murf427
Aug 02, 2012 | Hoover Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
Mar 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
16 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
