Question about Camp Chef Ranger III Table Top Stove
RANGER STOVE SE ERROR - Camp Chef Ranger III Table Top Stove
Mi ranger prende i se apaga a fuerza le prende el foco de la pila y la auja de la carga esta abajo no se que es alguien save
Diana si se enciende la luz de la bateria lo mas comun es que necesites remplazar el alternador asumiendo que la correa este en buenas condiciones
Aug 07, 2015 | Cars & Trucks
How do I fix my stove? None of the radiant elements are working.
Have you confirmed that you do have 220 volts at the range outlet? If you don't, turn your breaker off then on and recheck the voltage with a meter. Any losses of voltage through the breaker indicates you may have a bad breaker. (Do this with the stove unplugged from the stove power receptacle). Next, have you pulled one of the elements off the stove and checked it with an ohm meter to see if you have continuity. No continuity indicates the element circuit is incomplete and the element needs to be replaced (you should have a reading on the ohm meter if the element is good).
Dec 30, 2014 | Samsung Electric Convection Range...
Error code
found sensor inside oven no continuity am ordering new sensor should fix problem
Jan 08, 2009 | Ovens
Entire microwave is dead except LED screen which has a message -- E 5 -- Spoke to Samsung who told me to unplug it for 10 minutes - that dosn't do anything. This is a top of the line over the stove...
From the Samsung FAQ:
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater (sic) to find your nearest Authorzied Service Center.
It may be a failed sensor.
Sep 11, 2008 | Samsung Microwave Ovens
Camp Chef Ranger III Table Top Stove Logo
690 people viewed this question
Top Camp Chef Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Camp Chef Furniture Expert? Answer questions, earn points and help others
