Question about Muratec F-300 Fax
Fax result T.1.1 - Muratec F-300 Fax
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 10, 2009 | Minolta bizhub 200 Copier
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Discontinue fax transmission report
Press;
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
  • OK
  • Exit
  • User Tools/counter button
Good luck and please rate me, thanks.
Jan 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper jam
sounds like you have a problem with the mechanicals, have it check by a certified tech. or junk it....hehehe!!!!
Jul 24, 2008 | Panasonic KX-FP101 Plain Paper Thermal Fax
Cannot receive a fax
I called the Sharp Electronics Corporation 1 800 237-4277 who put me in touch with service personal. They walked me through the problem. They were very nice, easy to work with, patient and very professional. They resolved my problem at no cost. Great working with them. Daryl Thunder Bay Ontario
Jul 03, 2008 | Sharp UX 465L Plain Paper Thermal transfer...
Hp officejet 7310 fax problem
Just change below settings
Press setup on the all in one. Navigate to Advanced Fax Setup using arrow key. Set the FAX Speed to Slow and turn off the ECM (Error Correction Mode). Try sending fax. Please simply send a fax (single page black and white text) (1-888-473-2963 . Check for the result.
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
About brother 212 fax machine
1- could be the lamp is not coming on
2-is there a lot of toner in the machine?
Dec 05, 2007 | Office Equipment & Supplies
Muratec F-300 Fax Logo
82 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
