Question about Cycling
Handlebars raise marin cs.01.3
Can i raise the handle bars
  • 132 Answers
SOURCE: raising the handlebar how do you do it?
PUT THE FRONT WHEEL BETWEEN YOUR KNEES AND TWIST HANDLE BARS FROM SIDE TO SIDE THEN SIDE TO SIDE AND UP AT SAME TIME THIS PART OF THE BIKE CAN BECOME RUSTED AND STICKY INSIDE TRY SOME WD40 OR ANY SORT OF OIL TO TRY AND GET IT MOVING AND BE SURE TO RE TIGHTEN NUT BEFORE USE HOPE THIS IS HELPFUL GLENN......
Posted on Nov 15, 2008
bikeservice
  • 34 Answers
SOURCE: Can I raise the handlebars on my Marin hybrid bike
Most likely you have a threadless headset on your Marin which means you can not raise the handlebars without replacing the stem or handlebars themselves. In addition, many times you will also have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you do not have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps. If you need any more help you can connect me at elijah@starbikesfl.com. Thank you
Posted on Jul 18, 2009
  • 6 Answers
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Schwinn Impact MOS.....can the handle bars be raised...
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
Posted on May 22, 2010
Testimonial: "Very Helpful because it is not an ordinary handle-bar and I didn't know which one to loosen. "
Coachphil
  • 347 Answers
SOURCE: I would like to raise
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Posted on Nov 18, 2010
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
How do you raise handle bars?
There is a long bolt at the top of the neck which is used to pull a tapered nut into the bottom of neck.
Loosen this bolt by 3-4 turns and tap it down to release the taper. Secure the wheel from turning while turning the handlebars and the handlebars can then be raised or lowered as required. Straighten the handlebars in relation to the wheel and retighten the neck bolt and you are done.
Aug 16, 2015 | Cycling
How do you raise the handlebars on a next bike
Loosen the center post bolt and wiggle the handlebar back and forth while pulling up. There isn't much height adjustment. You can get a longer center post from a bike shop if you can't get a comfortable adjustment.
Sep 24, 2014 | Cycling
Raise handlebars
There is a bolt on the top of the goose neck that hold the handlebars in place. It should be a 1/2 inch, some are metric so just find the right size. Loosen this bolt about a half inch to an inch. It will be sticking up out of the neck. Tap it in with a hammer, it will go loose. Now just raise the handle bars where you want them and re tighten the bolt.
Aug 12, 2012 | Trek 7.5 FX
I have a Sirrus bicycle made by Specialized. Is there a way to raise the handlebars?
There are a number of ways to raise the handlebar, depends on how old your Sirrus is.
The most common is too replace the stem with one that has a higher rise to it. Take your bike into your local bike shop and have them take a look at your set-up and they can offer specific options depending on how high you want to raise the bars.
NOTE: Depending how high you raise your handlebars you may need to replace your cables and housing to your controls. Also you may have handling issues if you raise the bars too high. If you are raising your bars because your uncomfortable or having pains in the neck or back you should consider getting a bike fitting to make sure you are properly mated to your bicycle.
Mar 20, 2011 | Cycling
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
How to raise handlebars on diamond back outlook bike??can't figure it out help?
If it is a conventional handlebar stem, loosen the bolt on the top of the handlebar stem a couple of turns, tap the bolt with a hammer.
The bolt should drop down, at this point the bars should be loose.
Do not raise the handle bars above the safe limit line as the stem could break of come out .
Once you have them where you need them, re-tighten the bolt.
Hope this is of some help.
Ed
Apr 24, 2009 | Cycling
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
