Question about Lowrance Endura Out&Back Handheld GPS Receiver
Troubleshooting lowrance out&back Endura GPS after turning on the opening screen shows but nothing happens when any button is pressed, no touch screen and the off/ on button will not shut down the
None of the buttons will change eh initial opening screen
SOURCE: iway 350c GPS battery
I don't know if this is the recommended way. Hold the unit facing you and look at the top of the unit. There is a seam about ¼” from the front. I simply used a small jewelers screwdriver and inserted it at the top of the unit about 1" from the side. I lifted the front section a little bit. It released one of six tabs that hold the face plate in place (two on top and two on each side). Repeat the same step on the other side then the sides. When you remove the face plate the silver on/off button will fall out, but don’t worry about that. Here is the tricky part. It has four star screws holding the back of the case to the electronics unit. I took a trip to the local Harbor Freight store and bought a star wrench set for $3.99. Remove the four screws and presto you can take the back casing right off. The batteries are at the bottom, but I can’t find any info on what type they are, so I don’t know what to replace them with, at least not yet.
Posted on Oct 17, 2008
SOURCE: lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Posted on Oct 28, 2008
  • 9 Answers
SOURCE: Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Posted on Jun 24, 2009
SOURCE: how do you get geocaches on a lowrance endura gps.
Loading Geocaching information on the Endura Safari GPS
You can load individual caches into the Safari as a .loc file or load a pocket query file of up to 500 caches as a .gpx file.
The trick with the Safari is to load these onto the unit using the data cable that comes in the box. Connect the Safari to your computer using the data cable and transfer your .loc or .gpx files into the GPX folder on the device.
These files have to be in this GPX folder to be recognized by the device. It will not work if you load the .loc or .gpx files onto a microSD card and insert it into the bottom of the Safari. I am told that this will be fixed in the 1.2 software update that is supposed to come out at the beginning of December.
Once you have the files loaded, all you have to do is disconnect from the computer and wait for the Endura to restart, go to Main Menu --> Find --> Geocaches and see all of the caches listed. For .loc files, there will be limited information provided from Geocaching.com. For .gpx pocket query files, you will have access to the full description, cache size, terrain difficulty, find log and hints. The great thing about the Endura GPS products is that they have a great filter function for geocaches. I use this with my 7 yr old daughter when I only want to find caches that are easier to find and have full size traditional caches that are more likely to have better "treasure" inside. Hope this helps. Have fun!
Posted on Nov 16, 2009
SOURCE: Lowrance Endura Safari screen has gone white.
sorry to say but its broke, same thing happened to me after one day of ownership, lowrance tech support had me return it for a replacement, he called it the white screen of death.
Posted on Jun 08, 2011
ENDURA POWER BUTTON BROKEN
Sounds like the power button is pulled loose from the circuit board or the power switch went bad for some reason. You can't check this out as it is sealed to be waterproof and opening it violates the warranty. The only way to address this would be to send in to Lowrance Customer Service.
This should not be a common problem and should be covered by manufacturers warranty if still within the 1 yr warranty period. If out of warranty, Lowrance Customer Service should still be able to replace or repair it for some sort of cost.
To speak with US based Lowrance Customer Service, call toll-free at 1-800-324-1356, Monday through Friday from 8:30 am to 4:45 pm Central. Or email them at products@lowrance.com with problem, product model and serial number (located between the batteries in the battery compartment). CS On Hold times range between 0 and 4 minutes right now with Monday mornings being their busiest times.
A Lowrance Guy
Jan 30, 2012 | Lowrance Endura Out&Back Handheld GPS...
Why wont my lowrance endura outandback upload the 2010 lake master chip put in i updated the firmware and it still wont work
Two requirements:
1) You must have version 1.4 software on your Endura. Remove the map card, press and hold (10 sec.) the menu key until software information appears to see what you have. Upgrades are available on Lowrance's website.
2) You must have the Endura Compatible LakeMaster map card. These were made available in May 2010. The packages have an "Endura Compatible" sticker on the front.
Call LakeMaster regarding your options if the card is not Endura compatible.
Moccasinboy
Nov 27, 2010 | Lowrance Endura Out&Back Handheld GPS...
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
May 31, 2010 | Lowrance Endura Safari Handheld GPS...
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
Lowrance Endura-projections other than Lat/Long?
Yes, if you download the newest firmware upgrade version 1.2 it will add in other projections and datums, as well as fix other known issues. I would recommend that you run both the 1.1 and 1.2 upgrade for your Sierra, the 1.1 upgrade will fix some issues with the base map.
Both upgrades can be found at the following location: http://www.lowrance.com/en/Endura/More/
I hope this helps.
Dec 09, 2009 | Lowrance GPS
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
May 25, 2009 | Garmin Nuvi 660 GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Garmin nuvi
Different parts of the screen do different things depending on the mode you're in. When you touch "speed" the trip screen appears as you've already noted. The 'Driving" icon does nothing until you've asked the GPS to take you someplace.
After you enter a route the "speed" icon changes to "arrival" (which will still bring up the trip screen) and the 'driving' icon will change to "Turn In." Touching "Turn In" will bring up a list of turns along with a small portion of the map (showing that particular turn) anytime you've entered a route.
Note you can also press the green banner on top of the map when you have a route set. You'll see a list of just the turns and the distance to each. Touching each of those turn boxes will show you the split screen offered after you touched the "turn in" button.
Cheers
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Lowrance Endura Out&Back Handheld GPS Receiver Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
