Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Bizhub250 time setting - Konica Minolta bizhub 250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 21, 2016 | Minolta Office Equipment & Supplies
How do i get an event log on bizhub250?
No such item. must use the meter count meter. if so some one use the machine. did you use the had count meter or the one on the screen hard count is inside toner cover
Mar 07, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
The error code appearing on our bizhub250 is c2557
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jun 11, 2015 | Konica Minolta 250 Bizhub Copier Fax...
Bizhub250 - waster toner box replace
open the front door to your left next to the yellow image unit press the button an pull out the waste box and install new one.
May 07, 2014 | Konica Minolta bizhub C250 All-In-One...
Connect me to bizhub250
doe it have a network connector rear upper cover
Jan 10, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
I have a Bizhub 250/350 Konica Minolta it has a
the device takes too long to warmup. try switching off then back on when you see the message. if that does not work you will have to call for a technician i'm afraid. good luck
Apr 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
