Question about Plumbing
Oil submersible pump
My ace brand water pump ran dry for a few days on accident. Now it still works but has released a white oil into my rain water collection cistern. Can I use this water still to water my garden or give to animals?
    Top Expert:
  • 3,698 Answers
No, it may nto be. It is contaminated with oil/grease.
Posted on Aug 20, 2014
The pump has gotten where it pumps a few seconds and stops ,I thought maybe it's low on oil
Most sump pumps are sealed so they have no way to add oil. I would see if your pump discharge line has a check valve installed in it.It should have a check valve installed so that waste can only flow away from pump.Otherwise the pump can cycle for a short period,shut off and have water in vertical pipe flow back into sump basin causing pump to cycle again. Also if your pump does have a check valve in it make sure that it doesn't have anything caught in it that would stop it from closing completely. Some pumps have a check valve installed on the pump. It is also possible that you may have something caught in the pump impeller. you will need to remove pump to inspect the impeller. Hope this helps you. Thanks
Nov 22, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Is the internal motor in a tsurumi 50pu2-15s
No it should be completely dry and clean, check the date of purchase, you will need to replace the mechanical seal and clean the motor,its not suppose to happen,
ask your tsurumi distributor if you want to repair it or ask about the warranty, i am assuming that the pump stop working so thats why you open it and ask about it here, make sure you dont see any burn (black) wire on the stator, if you see any burn on the stator its a bad news,
If there is no burn part,
If you have just a few dip of oil in the motor try to remove the oil as much as you can with (electric part (brake) cleaner) or rag and replace the mechanical seal,
If there is a lot of oil all over in the motor, if he is not already damage (Burn),you can try to wash the motor with clean or light soapy water and then let him dry for a few days or in a oven to make sure all the water is evaporate, then replace the seal and cross your finger,we can never be sure that this procedure will work due to this small electric motor, and you never know how long the motor might have run with liquid in it, but i say its 51% succesfull chance to work, if you have to pay someone to do that it might be worthed to buy a new unit.
Hope i help you,
Tsurumi Man
Everywhere, Always
May 22, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Water ace pump it will pump it out but it comes back in
Do you mean it won't pump last inch of water or so? sump pumps are not designed to pump completely dry. vane pumps will pump dry. If you are pumping from one tank to another and after pumping is complete, and fluids transfer back, install a check valve on output hose to prevent back-siphoning , or don't submerge output hose on other tank. Hope this helps.
Feb 05, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
Submersible utility pump needs oil,what kind should I use in it.
What looks like 'oil' coming out of your pump is actually water! It has leaked and is fully contaminated. The seal for the pump must have leaked and it filled up. Take the 'big screw' back out and drain it and let it dry for a couple days. Then use some silicone as a gasket and put it back together. You may run again! It will probably fail sooner rather than later with a bad bearings from the water damage. That's what gave it the oily appearance.
Aug 26, 2009 | Craftsman Professional 1/4 Hp Submersible...
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Oil type
these pumps are supposed to be sealed and not to be able to oil,,
Jun 28, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Plumbing Logo
211 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
