Question about Konica Minolta Office Equipment & Supplies
31 error code - Konica Minolta Office Equipment & Supplies
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Jkl jl
Posted on Mar 11, 2017
  • Konica Minolta Master
  • 6,421 Answers
What model ######################
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
Dell error code 31
Open Control Panel and then Device Manager (or System, then Device Manager).
Look for a yellow balloon, this should show you which device is giving the Code 31 error.
Then you need to fix the problem by re-loading the driver.
Mar 04, 2015 | Dell Computers & Internet
Error code 31 always appear on the dialog box
Try to check this Code 31 Resolution from this page
http://pcsupport.about.com/od/findbyerrormessage/a/code-31-error.htm
I hope this information will be helpful. Thank you for using FixYa!
Jun 07, 2011 | Computers & Internet
Check engine codes for a 1997 stratus the codes coming up are 12 31 and 55
12 Recently disconnected the battery (always stored)
55 End test.
CODE 31... depending on the model, code 31 can refer to two different systems. Please choose from one of the above links for specific information on each system.
Wastegate Solenoid Circuit Error
The ECM regulates turbocharger boost by opening and closing the "wastegate" as necessary. (The wastegate is a vacuum operated bypass valve that limits the ability of the turbo to provide boost.) The Wastegate Solenoid regulates the vacuum supply to the wastegate for proper operation.
Fault Code Description
  • 31 - Wastegate Solenoid circuit error
Symptoms
  • Lack of power or engine "ping" due to overboost by the turbocharger
Common Problems
  • The wastegate solenoid would be the most common cause for code 31 to set
  • Code 31 does not indicate a problem with the turbocharger or wastegate
Gear Position Switch (PRNDL) Error The Gear Position switch tells the ECM which position the shifter is in. The ECM will use this information to inhibit starter operation, change the transmission shift pattern as necessary, and provide the information for the electronic shift indicator display on the dash.
  • 31 - Gear Position switch (PRNDL) error
Symptoms
  • Engine may not crank over in Park or Neutral
  • Electronic shift indicator may flash
Common Problems
A maladjusted or failed Gear Position switch would be the most common cause for a code 31
Hope helps with this (remember rated this post).
Jun 30, 2010 | 1997 Dodge Stratus
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Jun 18, 2010 | Computers & Internet
Isatap adapter????error code 31,cant get onto internet,wont find my router or any other devices,really stuck on this one?
Use System Restore to revert device drivers and registry configurations back to a state previous to the Code 31 error. Be sure to choose a restore point from a date and time before you know or suspect that the Code 31 error first appeared. 8. Disable any hardware-based security on the device.
for more help visit CBR Tech Solutions
Jan 22, 2010 | HP Computers & Internet
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Error code C:31:40
After looking up the error code C:31:22, I saw all of the solutions for slapping the side of the camera. Slapped it 4 times, then the error code switched to C:31:23. Same solution... Whacked it 4 times, then the error code switched to C:31:40. Again, whacked it 4 times. Opened it up, turned it upside down and a rubber roller dropped out of the camera. I could see where it went, snapped it down on its metal peg and it works fine. Looks like its the rubber rollers that guide the tape that gets stuck. Before whacking it, make sure the RUBBER roller moves freely. Good luck!!!
Apr 14, 2008 | Sony Handycam DCR-TRV240E Digital...
Error code M627-31 WHAT'S THIS?
não sei o que aconteceu com minha câmera da HP, quando ligo aparece a seguinte mensagem?: Lens Error: M627-31
Mar 23, 2008 | HP PhotoSmart M627 Digital Camera
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
