Question about Fowler Ip54 0-6" / 150mm Electronic Depth Micrometer
Rod change depth gauge
How to change depth rods
Just changed fuel pump on 2005 f250 4x4 and fuel gauge moves up tom 1/8 tank and reads low fuel on full tank, why is my fuel gauge not working correctly
The fuel sending unit rod was bent during the instalation giving you the false readings. This is the thin metal rod that attaches the float to the sender.
Sep 29, 2014 | 2005 Ford F 250 Super Duty
Engine making very loud noise when started
have you compression tested the cylinders ? if you dont have a gauge you can remove spark plugs and put your finger in plug hole and crank over and see if it blows your finger out ! could have bent the inlet or exhaust valves as well as the piston !
Feb 13, 2014 | 2002 Yamaha V Star 1100 Custom
5hp rotary hoe , blades under engine.Hoe does not want to move foward,seems to just dig it self a hole,and you must either try to push it forward,or rock it side to side to get it moving,it makes it very...
My rotary hoe has a steel rod that you can adjust for the depth and if that rod is set too far in the ground it will just sit and spin. my rod has holes in it and you set it with a pin that makes it less deeper if you want.
Feb 15, 2018 | Garden
No reverse after i park my 1962 ford automatic
Fluid level and a dirty filter are the first things to check, then a band adjustment is next on the list. as the pan needs to come off to change the filter adjst the bands at the same time. the tea levels in the bottom of the oil pan will tell you in there are more serious issues inside.
Terry
Nov 25, 2012 | Cars & Trucks
How can I adjust the water level in the tank?
With a standard Fluidmaster fill valve, on the side of the float there is a rod that controls the depth of the float. On top of that rod is what looks like a phillips head on a screw. You can use your fingers usually, but if you would like you can use a screwdriver, simply move the float level up and down by screwing either clockwise or counter clockwise to change the level in the tank. Flush a little water after making the adjustments to guage the water level when the fill valve shuts off. Good luck
Aug 14, 2010 | Fluidmaster & Fits-All Faucet Connector
Where can I find a replacement depth gauge for a Hilti TE6-C
(Good) Search "Hilti" to find sellers ...
(Better) check the advertisers here at FizYa.com
Oct 30, 2009 | Drills
I just received a 693 plunge router via internet order. As soon as i took out the plunge part out of the case and moved the lever it pupped up and now will not move up or down > Is there something I am...
The plunge base is spring loaded. When you move the lever is springs to the up position. To lower it place the base on a flat surface, press and hold the lever down and push down on the handles. The router bit height should be set on the depth rod with the base in the down position. Then release it to the up position. When you have positioned the bit where you want it on the work piece, press the lever and "plunge" the bit down into the workpiece. The depth rod setting will stop the bit at the depth you set it for.
Oct 21, 2009 | Porter Cable 6931 Plunge Router Base For...
I'm looking for the 2000 isuzu rodeo 3.2L v6 connecting rod bearings torque specs.
1. Check the connecting rod alignment If either the bend or the twist exceeds the specified limit,the connecting rod must be replaced. Bend per 100 mm (3.937 inch) Limit: 0.15 (0.0059) Twist per 100 mm (3.937 inch) Limit: 0.20 (0.0078)
2. Measure the connecting rod thrust clearance. Use a feeler gauge to measure the thrust clearance at the large end of the connecting rod If the clearance exceeds the specified limit, the connecting rod must be replaced. Standard: 0.16 mm - 0.35 mm (0.0063 inch - 0.0138 inch) Limit: 0.40 mm (0.0157 inch)
3. Measure the oil clearance between the connecting rod and the crankshaft.
    1. Remove the connecting rod cap nuts and the rod caps (12). Arrange the removed rod caps in the cylinder number order.
    2. Clean the rod bearings and the crankshaft pins.
      1. Carefully check the rod bearings. If even one bearing is found to be damaged or badly worn, the entire bearing assembly must be replaced as a set. Reinstall the bearings in their original positions. Apply plastigage to the crank pin.
      2. Reinstall the rod caps (12) to their original positions. Tighten the rod cap nuts. Torque: 54 Nm (40 ft. lbs.) Note: Do not allow the crankshaft to rotate.
      3. Remove the rod caps.
        1. Measure the width of the plastigage and determine the oil clearance. If the oil clearance exceeds the limit, replace the rod bearing as a set. Standard: 0.019 mm - 0.043 mm (0.0007 inch - 0.0017 inch) Limit: 0.08 mm (0.003 inch)
        2. Clean the plastigage from the bearings and the crankshaft pins.
May 21, 2009 | 2000 Isuzu Rodeo
Depth Rod Question
Depth Rod - A devise mounted on the side of the drill that lets the user know when they have reached the desired depth.
Aug 27, 2008 | Makita Rotary Hammer 240 Rpm, 2150 Bpm, 15...
Fowler Ip54 0-6" / 150mm Electronic Depth Micrometer Logo
78 people viewed this question
Top Fowler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Fowler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
